11-21-2008, 11:32 AM
il
427so vs 482so
Is there any advantage or disadvatage between the 2? Mild builds(not wild)
11-21-2008, 02:21 PM
torque and TORQUE
Too many toys?? never!
11-21-2008, 02:23 PM
Ill
The 482 has a 1/2 longer stroke---that means that the piston travels an extra inch every revolution---higher piston speed
The ideal FE for a cobra would probably be a 427 destroked to 396" like they ran at the short Nascar tracks
Jerry
11-22-2008, 12:40 PM
if i had to do it all over again i would stick close to the factory 427, you can't even get all that hp and torque to the ground. there is no advantage to doing a burnout at 70 mph.
Fred
11-22-2008, 12:41 PM
il
good point!
11-22-2008, 04:59 PM
OH
I have a 427 (actually 429 ci, 4.250 bore, 0.017" over) in my car, and it put 488 ft-lbs of torque at the rear wheels. A 477 ci in a similar car put 476 torque at the rear wheels. My friend who has a 482 hydraulic roller built by a respectable builder, on a different dyno, put 420 ft-lbs at the rear wheels. Yeah, for any given build, the extra cubes will give you more torque, but 427 ci will give enough as well.
If you get a used complete motor, you don't have to buy another crank. The engine will remain a "true" 427.
If you buy a stroker crank, 3.98, 4.25, etc. you get more cubes, but also you get BBC rod journals, that are slightly wider and shorter, which is better. You will also get more torque, although top end HP will be closer to the same.
No matter which way you go, you'll be fine, assuming you put it together correctly.
11-23-2008, 03:48 AM
What gears and trans are you using
11-23-2008, 04:54 AM
Originally Posted by RICK LAKE
Still got a buzz on Rick??
11-23-2008, 06:36 AM
Mi
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
11-24-2008, 02:51 AM
I have the FLU
11-24-2008, 08:41 AM
I know, fighting the same crud myself.. Mine hasn't gone to my fingers though.. Get well buddy!!
Dave
