Old 11-24-2008, 07:10 AM
CobraEd's Avatar
Default Zddp
http://eastwood.resultspage.com/sear...=custom&w=zddp
________
________
Old 11-24-2008, 07:45 AM
Bob In Ct's Avatar
Or you can use Redline, 1,200 PPM ZDDP (Zinc Dialkyl Dithio Phosphate) even in their 5W-30. Redline also sells ZDDP additive. Mobil1 has 800 PPM in their 5w-30. I had the Redline 5W-30 tested and the testing backed-up their numbers.
www.redlineoil.com
Redline is available at
www.hrpworld.com
Old 11-24-2008, 09:37 AM
zrayr's Avatar
Cobra Make, Engine: Fords
www.redlineoil.com
www.hrpworld.com
I use Mobil 1 15W-50. It has 1200 ppm ZDDP also.
Z. Ray
'65 K code Mustang
'66 Galaxie 500
Old 11-24-2008, 10:43 AM
Wayne Maybury's Avatar
Canadian Gashole
Default Stp
I contacted STP a couple or years ago when we first discussed this topic. They told me that their oil additive contains a high level of ZDDP.
Unfortunately, even the diesel motor oils like Rotella T now contain reduced amounts of ZDDP but I believe that they tend to still have more than most oils for gasoline motors.
Wayne
Old 11-24-2008, 12:12 PM
Nedsel's Avatar
Original Shelby Owner
I think you will find that Mobil has been reducing the amount of zinc in their oils. The old SL-rated Mobil 1 may have had 12000 ppm of ZDDP, but the new SM designation has reduced that. Better check the specific formula of the new oil, or use the SL variety as long as possible.
Ned Scudder
Old 11-24-2008, 01:23 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
There was a motorcycle oil additive that was very high in the ZDDP levels...
I try and find it unless someone remembers the mane of the product...Don't remember if it was a 2-cycle or 4-cycle oil additive.......
SPFWiringDiagrams@Comcast.net
Old 11-24-2008, 01:44 PM
Bob In Ct's Avatar
I may be incorrect, but I'll bet you can have too much viscosity and/or too much ZDDP.
Do you really want 1,800 PPM ZDDP? Is 15W-50 too thick for a typical street engine? When does the oil stop going through the engine and start going out the by-pass valve?
Old 11-24-2008, 02:05 PM
acmjg's Avatar
Cobra Make, Engine: Homebuilt, .060 over 428 FE Dual Quad
Default Valvoline VR1
How about Valvoline VR1? I was told that it has a high ZDDP content.
Old 11-24-2008, 02:18 PM
scootter's Avatar
VR1 states that it has higher levels of ZDDP in their oils. The only problem they don't make a 10-40. I used their 20-50 in the past and it was like pouring honey into the engine.
I bought a box of the ZDDP from the distributor that I've been using.
Scott
Old 11-24-2008, 02:48 PM
Cobra Make, Engine: SPF #1019
Scott
I found some on ebay and bot it...
