Old 12-10-2008, 11:40 PM
Cobra Make, Engine: Hurricane Motosports
Default V-Band and mild steel flange
For those of you that are familiar with v-band clamps...I am looking for a supplier that has mild steel v-band style flanges and a stainless steel v-band clamp. The flanges need to be 3.5". I have found numerous aluminum and stainless but no mild steel to weld to my existing exhaust. I am in the process of upgrading my sidepipes and would like to ad that feature for future upgrades or options. Thanks bermblaster
Old 12-11-2008, 05:24 AM
http://www.spdexhaust.com/pdfs/36-39...st_Flanges.pdf
They have the flanges in both 1020 carbon steel and 304 SS.
Not a bad idea. I'm looking at changing to a less restrictive muffler and this may be a better alternative to an all welded installation.
Old 12-11-2008, 05:44 AM
Chaplin's Avatar
Yup, put them on my car last year, they work great. Now I have 3 sets of mufflers that I can swap out in about 15 minutes depending on the amount of noise that I want/don't want. I got mine from SPD as well.
Replica is not a dirty word.
Old 12-11-2008, 06:57 AM
Cobra Make, Engine: jbl
http://www.burnsstainless.com/Hardwa...ps/clamps.html
Old 12-11-2008, 08:52 AM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
http://store.racing-solutions.org/vbands.html
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
Old 12-11-2008, 10:46 AM
jmarsey's Avatar
Cobra Make, Engine: A Blue Car
I've done several of these and about to do another setup on my spec racer. SPD is where I get all my exhaust bits. They are the best I've seen.
Talk to Chris: (916) 635-8108
NASA - Instructor - 2012 TTA Champion - We Drive Harder!
Old 12-11-2008, 11:09 AM
When I did mine I used Burns 3.5" stainless flanges and clamps. I had them tigged to mild steel exhaust pipe. Collecters to mufflers and then to turn out pipe. In total I have three sets of interchangable mufflers. EM original , Lo-Bak, and straight through open pipes. I used the staggered flange method creating a male to female connection. One side of the joint the pipe is inside the V-flangefrom the flange mating surface, the other side of the joint, the pipe protrudes from the V-flange mating surface a matching length so the gap in the pipes is staggered so it doesn't line up with the gap in the flanges. Leakage is minor and manageable. I was then able to have the 2 piece headers (from engine to inside body and then through body -turn and collecter), 2 sets of mufflers and open pipe (muffler substitute), and turnout pipe, all ceramic coated inside and out and tumble polished. My setup has the muffler hanger bracket secured to each muffler. My exhaust is rich and slobbers some. Some of it manages to escape the joints. Almost absolute but not exactly. Given time it should coke up seal off . Burns offered a reduced price on the V-flange and clamp kits, if ordered in quantities . I ended up using 8 kit sets of flanges and clamps but didn't anticapate the total quantity and ordered the kits in small bunches. I can change mufflers with a whench and screw driver. I have the hot mufflers covered with the perforated SS shrouds from Finish Line accessories.
Mike H
Old 12-11-2008, 01:03 PM
Thanks for the info. I will be contacting these guys and get more info. I will need to go with the carbon/mild steel do to not having a tig welder. Thanks again for the web sight info.. Bermblaster
