02-02-2009, 04:25 PM
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
MSD Digital 6
Went to go for a ride this weekend and for the first time ever my car wouldn't start!!! Long story short, no spark (even though I drove the car into the garage and parked it just a few weeks ago). Power to the ignition, distibutor turns, MSD powers up (red light) all wires tight and clean.
Bad coil or bad box?
Went througth the MSD trouble shooting, couln't get an ark out of the coil when manualy triggering the ignition...
Now I'm questioning the reliability of the MSD Digital 6??
Any comments?
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
02-02-2009, 04:44 PM
If it's an MSD dist and cap,check and see if the carbon ball that contacts the rotor is still in place.
There have been issues with them
02-02-2009, 04:51 PM
MSD Distributor and the ball is intact.
BDR 559
SBF 410
HP= Enough!!
02-02-2009, 05:45 PM
http://www.msdignition.com/uploadedF...09_pickups.pdf
Use an Ohm meter and check the magnetic pickup in the distributor for the values stated: If this is Correct then check with an alternate coil, lastly remove the box and have it checked.
02-02-2009, 05:52 PM
my money is on the pick up in the distributor
02-02-2009, 07:23 PM
Rick,
Thanks for the info, I will check the reading tomorrow. I just assumed the magnetic trigger was pretty much bullet proof...
I had heard a few comments on the Digital series leaving a few people stranded in the past. I personally have never had a coil or trigger fail, but have experienced an ignition module/box to fail.
BDR 559
SBF 410
HP= Enough!!
02-02-2009, 08:21 PM
Speaking from experience, double check the ground..
02-03-2009, 02:47 AM
400 to 1000 on the magnetic pick-up ohms, they usually fail with open windings.
dave
Too many toys?? never!
02-03-2009, 06:22 AM
OK
Cobra Make, Engine: Fords
I'm using the digital 6, so far (5 or 6 years ) no trouble. Distributor is the msd ready to run, coil is the epoxy filled msd blaster 2
Z. Ray
'65 K code Mustang
'66 Galaxie 500
02-03-2009, 06:26 AM
NJ
I had an MSD dist pickup go bad on me once. Fortunately, I have the dual pickup dist and just plugged the other one in.
Roscoe
Roscoe
02-03-2009, 03:51 PM
Bad pickup, couldn't get any ohm reading at all... $28 later I'm back on the road, I will throw a spare pickup in the trunk...
Thanks for everyones input.
BDR 559
SBF 410
HP= Enough!!
