December 2025
Old 02-16-2009, 06:53 PM
428street's Avatar
Cobra Make, Engine: BRG ERA street car w/428 PI, Sunburst wheels, undercar exhaust, original interior, no philips head screws!
Default Fire Extinguisher help needed
Gentlemen:
I need some help buying a FE. I've seen some on-line for $25 to $200 and up. I don't want to cheap out on one but I am also close to tapping out on the money side. I know nothing about what is needed. Thanks is advance.
Old 02-16-2009, 07:45 PM
Ibr8k4vetts's Avatar
Just make sure it is rated of B and C.
Class B fires involve flammable or combustible liquids such as gasoline, kerosene, grease and oil. The numerical rating for class B extinguishers indicates the approximate number of square feet of fire it can extinguish.
Class C fires involve electrical equipment, such as appliances, wiring, circuit breakers and outlets. Never use water to extinguish class C fires - the risk of electrical shock is far too great! Class C extinguishers do not have a numerical rating. The C classification means the extinguishing agent is non-conductive.
Mike Z
Old 02-16-2009, 07:46 PM
428street's Avatar
Thanks Mike.
Old 02-16-2009, 08:14 PM
I keep a chrome Amerex A384T Halotron unit mounted between the seats. I keep the same model in plain old ABC powder in the trunk. If my car is on fire, I'll use the Halotron; if your car is on fire, I'll use the powder. The powder extinguisher, in chrome, will run you about $40. The same unit with Halotron will run you about $100.
Old 02-16-2009, 08:33 PM
Cobra Make, Engine: Kirkham #570 w Shelby FE
Basically two routes, dry chemical or Halide.
Dry chemical is the cheapest, but leaves a heck of a mess for clean-up.
Halide (Halon) is the safest, cleanest and most expensive.
I don't know if outside of track use that Cobras are any more prone to fires than any other street car. Electrical conductivity is not that big of a factor on a 12v car system.
Old 02-16-2009, 11:14 PM
RallySnake's Avatar
From what I've seen, most car fires are caused by gasoline leaks. After working on the system, I always test my gas line with full pressure from both pumps and feel all the joints before starting the engine. Gasoline fires are pretty hard to put out. I have actually saved two cars. I carry two extinguishers, a small pretty one in the cockpit and a big ugly one in the trunk.
Paul
Old 02-17-2009, 05:35 PM
428.. I got mine at Bethania-garage.com. They seem to have the best prices when I was looking around for one last year. Nice chrome styles for Halon and dry powder.
Old 02-17-2009, 06:46 PM
undy's Avatar
Ya can't have too much protection..
fixed Halon system, 6 nozzles under the hood, 2 behind dash and one in the driver's footwell. Plus... a Costco A/B/C dry powder type hand held extinguisher in the trunk, just in case.
BTW... The tie-wraps have been replaced with real bottle straps. (They sent me the wrong straps originally)
Dave
Too many toys?? never!
Old 02-17-2009, 07:14 PM
428street's Avatar
Thanks guys for all the responses.
Display Modes
