02-19-2009, 01:47 PM
OK
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
302 Stroker build
I might be buying a 1970 302 from a guy at work, never been rebuilt. I have thoughts of stroking it to a 331 or a 347. He also has a extra set of 302 heads with 351W valves installed.
What's the advantage of the 351 valves in these heads, make it breathe better? Also wondering if they'd be a good match for either the 331 or 347? He supposed to be getting me the head casting numbers tonight.
Not sure what cam I would use yet, any suggestions? I'm looking for about 350 HP, driven on the street only, no racing.
Any suggestions would be appreciated.
Juggernaut
02-19-2009, 01:57 PM
fl
You don't want to build a stroker (either a 331 or 347) and then kill it's performance potential by putting poor flowing heads on it - that's the whole reason for stroking the motor. There are SO many good heads out there for that application -AFR, Trick Flow, Brodix. A set of AFR 165's are perfect for a 331 - that's what I have on my Keith Craft 331. Plenty of power, great on the street, really nice sound.
02-19-2009, 02:12 PM
OK
Good advice, thanks.
Juggernaut
02-19-2009, 02:20 PM
No reason not to go with the 347 vs. 331. More cubes, more power.
6th generation Texan....
02-19-2009, 02:55 PM
Check your build cost before you buy anything. Machine work is the budget killer. Local builders here (Santa Cruz) were more expensive that buying a pre-built stroker from Keith Craft or Coast High Performance.
Just a thought.
DD
Dangerous Doug
"You're kidding, right?"
02-19-2009, 04:01 PM
OK
Just a thought.
DD
Thats exactly what I was thinking driving home from work. I think I'll just sit back and run some numbers before I do anything.
Time to go check out the Keith Craft website.
Thanks!
Juggernaut
02-19-2009, 04:06 PM
NJ
I did a 68 302 block stroked to 331 with AFR 185 heads. 3.25 Scat forged crank, JE pistons with a 1.250 piston height that were for a 351, and Crower Sportsman rods at 5.315". No wrist pin in the oil ring!
 Snakebit
02-19-2009, 05:04 PM
Juggernaut: I have a spreadsheet that I made apple to apple comparisons on 302 based engines for my FIA. PM me with your email if you want me to send you a copy.
DD
Dangerous Doug
02-19-2009, 07:26 PM
OK
DD
DD, sent you a pm.
Juggernaut
