  #41 (permalink)
Old 03-01-2009, 12:57 PM
FUNFER2's Avatar
I do have a straight axle and it would take a lot of work to change to a IRS, and maybe not even work at all. But thank you anyway,
Kevin
  #42 (permalink)
Old 03-01-2009, 01:24 PM
Hind sight being 20-20 I wish I had Kieth supply dyno #s below 4500 rpm just to see what the bottom end looked like. I opted for the .82 OD since there were a lot of people complaining about how sluggish the .64 made the acceleration.
Since I'm running the fuel injection, it's probably less of an issue than if I was running a carb.
Ideally the .64 would be a great 6th gear...
BTW don't forget about changing your input shaft if your going with an FE..
  #43 (permalink)
Old 03-01-2009, 01:38 PM
Just stick her on a chassis dyno. Keith runs his dyno numbers without anything on the exhaust (as do a lot of builders). Dyno numbers for an engine sitting on a dyno with no mufflers/sidepipes (and maybe no water pump, etc.) can be very misleading.
  #44 (permalink)
Old 03-01-2009, 03:43 PM
convincor's Avatar
not to hi-jack but anyone using a Fidanza flywheel??
http://www.fidanza.com/
02 Super Duty 7.3L
  #45 (permalink)
Old 03-01-2009, 03:56 PM
Cobra Make, Engine: Unique
Default gearing calculators
Here is two links for gearing calculators. One is preset with common rear gears and the other you can put whatever you want for a rear gear.
http://www.secondstrike.com/Technical/GearCalc.asp
http://www.classicchevy5speed.com/RPM-Calculator.aspx
  #46 (permalink)
FUNFER2's Avatar
A friend has one & likes it.
Kevin
  #47 (permalink)
Old 03-02-2009, 09:12 AM
DougD's Avatar
Default It's not the material, it's the weight
The material used (aluminum or steel) is less important than the actual weight of the flywheel. There are lightweight steel flywheels out there that approach the weight of aluminum.
For a street car, the rule of thumb I've been told is that the flywheel weight should be approximately 1% of the car's weight. A 4000lb car should have a 40-pound flywheel. A 2500lb car needs a 25 lb flywheel, etc.
  #48 (permalink)
Old 03-02-2009, 09:41 AM
FUNFER2's Avatar
Ya know, I never thought of that. I know you can get 40 lb and 20 lb. I havent checked but, for debate, how would a Billet flywheel be ?
Kevin
  #49 (permalink)
Old 03-02-2009, 09:43 AM
convincor's Avatar
The Fidanza weighs in at 14lbs.
You think that's to light??
02 Super Duty 7.3L
  #50 (permalink)
Old 03-02-2009, 10:04 AM
xracerbob's Avatar
I have the Fidanza flywheel on my 482. My feeling was that with 605 ft/lbs, I should be able to get the thing moving in first without too much trouble. I was/am trying to keep the total weight under 2350 which I think I have done. I have not driven the car yet, but in just checking the clutch release, it seems fine. As soon as the snow is gone (maybe July at this rate!) I'll find out.
  #51 (permalink)
Old 03-02-2009, 10:49 AM
FUNFER2's Avatar
That will be interesting. Please let us know how if feels.
Kevin
  #52 (permalink)
Old 03-02-2009, 11:20 AM
Default Centerforce
I have the Centerforce #900260 aluminum flywheel on my 428FE. Why, you ask, do I have the zero balanced 427 version on my 428? Because with the SCAT stroker crank you internally balance the assembly. The flywheel weighs just over 17lbs and works just fine for me -- I wouldn't change it. I have no idea why Centerforce wants $750 for it -- maybe it's the beautiful gold inlay. The competitors are charging half that for theirs.
  #53 (permalink)
Old 03-02-2009, 11:24 AM
FUNFER2's Avatar
$750, what's up with that !
"maybe it's the beautiful gold inlay"
Kevin
  #54 (permalink)
Old 03-02-2009, 11:35 AM
I don't remember it costing that much three or four years ago. And I don't have a good reason for spending the extra money on Centerforce if it did.
  #55 (permalink)
Old 03-02-2009, 01:24 PM
undy's Avatar
The Ram aluminum flywheel that Keith provided with my 482 weighs 20 lbs and is SFI rated (important to me). ..no problem at all getting her rollin' either.
Too many toys?? never!
  #56 (permalink)
Old 03-04-2009, 02:25 PM
Cobra Make, Engine: SPF 974
AL Flywheel = great investment.
Disadvantage ....slightly more drag on the decel vs steel FW
Advantages
Decreases centrifigul weight on the motor & makes car feel lighter to motor
Decreases the hit of the clutch on the tranny/tires due to less centrifigul force
Faster revs
Allows high reving off line wit less tire spin
Slows down faster
  #57 (permalink)
Old 03-04-2009, 02:38 PM
FUNFER2's Avatar
Dave- The Ram aluminum flywheel is part #2519. $425.
That's the cheapest I've found. I'll call keith.
Jam- that sounds correct. Thank you.
Kevin
