Old 03-08-2009, 03:29 PM
Cobra Make, Engine: Euro 427, Ford 302
Default Battery light does not come on
This is a recent phenomenon. I have a standard 3 wire Ford alternator fitted with one of these devices for a single wire conversion
http://store.alternatorparts.com/partnof7078.aspx
Just this morning I noticed that the battery light was not coming on when I turn the key. The battery seems to be charging although I have no voltage from the convertor to the warning light.
Anyone know of a way I can tell if its the alternator or the convertor thats faulty?
Drive It Like Your Hair Is On Fire
Old 03-09-2009, 05:56 AM
Ron61's Avatar
Post
Use a volt/ohm meter and with the car running measure from the back terminals of the alternator if you can get to them in your car. If you have voltage coming out, go to the input to the converter and see if it is there. If you have voltage going into the converter and none coming out, then you have most likely found your problem. Normally the battery should be reading about 14/15 volts when the car is running so that is what should be coming from your converter.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 03-09-2009, 04:50 PM
Hi Ron thanks for the reply. I'll test that at the weekend. I have three terminals on the alterantor: STA, BAT and FLD. Do you now which ones supply tha actual voltage?
JOhn
Old 03-09-2009, 05:49 PM
The BAT terminal supplies the voltage. For diagrams and a discussion of the light bulb that is not working see the following thread in which I included charging circuit diagrams and text from automotive books -- how the light bulb works is a neat little issue that a lot of people get wrong. First Drive today - speedo and electrically issues / help?
Old 03-10-2009, 09:20 AM
REAL 1's Avatar
Banned
Check the main fuse.
