Old 03-12-2009, 08:12 PM
sparks's Avatar
Default Lift installer
Does anyone know of a good lift installer in the northern il. area ? Not sure which lift I'm gonna get yet but I'm sure the installer mite have some good ideas.....THANKS
Old 03-12-2009, 08:33 PM
lovehamr's Avatar
Stolen Avitar
Just so you know; it's not all that complicated to install it your self. MY 12 yo son and I picked ours up from the freight terminal, loaded/unloaded and installed it by our selves.
Steve
Old 03-12-2009, 09:03 PM
HI Cobra's Avatar
I picked up my 4 post at the terminal and did the same - unloaded it
and put it together. Was going to get the neighbor to help some but he
wasn't home so I just kept putting parts together and danged if it didn't work!
Even with the spotty instructions wasn't bad.
Flip
Old 03-12-2009, 09:07 PM
CHRIS DAMSCH's Avatar
Cobra Make, Engine: SPF 1454
Put my 4 post together myself also.
Not that difficult. The runner with the hydraulic ram is extremely heavy though.
CHRIS
Old 03-12-2009, 09:18 PM
sparks's Avatar
Chris,what lift did u go with ??
Old 03-12-2009, 09:22 PM
HI Cobra's Avatar
Mine was the Danmark 7X (I think). It was the larger model and yes the
ramp with the ram was heavy!
Flip
Old 03-12-2009, 09:36 PM
Here's the one I went with.
http://www.gregsmithequipment.com/Di...ppro-park8.htm
The 8 plus raises a little higher if you have the ceiling height.
If you want to check it out feel free to stop on by some time.
CHRIS
Old 03-13-2009, 05:18 AM
Cobra Make, Engine: Unique 427SC
I'm in the midst of the lift decision myself. I've narrowed it down to these three...I think..ha..ha..
http://www.northerntool.com/webapp/w...9746_200359746
http://www.gregsmithequipment.com/Pr...Show=TechSpecs
http://www.americanautomotiveequipme...fts-p/tp9a.htm
Old 03-13-2009, 06:15 AM
csx wnab's Avatar
Cobra Make, Engine: superformance/427 fe ford
i just put mine together last night. it was easy........................like me.
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
Old 03-13-2009, 07:18 AM
lovehamr's Avatar
Stolen Avitar
Originally Posted by Bugman View Post
Bug, I'm pretty sure that "americanautomotiveequipment.com" is the same company that mine was built under. If I remember the employees bought it out. I chose them because at the time they were using all US steel. Most of the discount lift manufacturers are not, it's from China and there have been some failures. Some of them may be fine but I've had some tools from NH Northern that seemed to be made of peanutbutter. That being said I couldn't see my self under a lift that had suspect steel in it. So if I were you I'd check on that and the hyd. cylinder size. Those two things should give you a good measurement of relative quality. JMO, Steve
Old 03-13-2009, 08:13 AM
Put it together yourself. If you cannot assemble yourself you probably should not get one. Assembling gives you the knowledge you need to inspect and understand where to lubricate and inspect.
Old 03-13-2009, 08:16 AM
shelby101's Avatar
Default lift
Hey guy,
I had a 4 post lift put into my garage.
Gregg Smith in Indianapolis has a list of recommended installers you can use.
I have a 4 post lift.
Bill
Old 03-13-2009, 08:19 AM
FUNFER2's Avatar
Sparks and others wanting a lift. I can still get you a good deal with my "group buy".
2 post and all that's needed is a 8' ceiling. Let me know.
Kevin
Old 03-13-2009, 03:53 PM
Hey Kevin,
I may be interested this time around. Can you refresh my memory on the price, delivery, etc?
Rodger
Old 03-13-2009, 04:00 PM
sparks's Avatar
I would only be int. in a 4 poster.....My ceiling is 10 1/2'
Old 03-13-2009, 04:19 PM
FUNFER2's Avatar
Rodger- you have a PM
Sparks- I can explain more in detail if you called me.
I'll send you a PM with my number. You can call now or around 8:00 PM central. I'll be leaving at 6:00 PM for an hour or two.
If not today, I should be home all day tomorrow.
Kevin
Old 03-13-2009, 04:45 PM
Thanks Kevin. You have a PM.
Rodger
Old 03-13-2009, 06:31 PM
ZOERA-SC7XX's Avatar
I installed a 4-post with help from my GF. It's not difficult, and you only need a roll jack and a couple of jack stands to line up and position things. It also helps you to understand what you have.
