Old 03-14-2009, 02:56 PM
767Jockey's Avatar
Default Where to buy rubber grommets for thicker Fiberglass firewall?
Unless I am missing them, I don't see thick panel rubber grommets in McMaster Carr for using on my firewall and other panels in my car. I'm about to start the electrical part of the project. It seems that a grommet to fit a 1/4" thick panel is the thickest panel thickness I can see in McMaster-Carr, and even then it is only in very limited sizes. As best I can tell my firewall is about 1/4" thick, and then I have an aluminum panel over that. Also, I have wires to pass through bulkheads and such, all of them seem to be 1/4" thick. Any ideas where to source this stuff, guys? Thanks.
Doug
Old 03-14-2009, 06:37 PM
Cobra Make, Engine: jbl
i picked up some grommets at an aircraft surplus supply house.
Old 03-14-2009, 07:11 PM
convincor's Avatar
Cobra Make, Engine: FFR 390 toploader IRS
anything here that would work?
http://www.aircraftspruce.com/catalog/appages/an931.php
FFR MarkIII,FE,toploader,IRS,3.27,Vintage pin's SOLD!
68 F100 Custom Cab 418 cube FE/auto
99 SuperDuty Tuner/chipped/4" Banks TOTALED!!
02 Super Duty 7.3L
Old 03-14-2009, 08:46 PM
xlr8or's Avatar
Depending on how big you want them you can use valve cover breather grommets. They are grooved for about a 1/4 inch thick panel and work pretty well.
Old 03-14-2009, 11:40 PM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Boat builders should be able to point you in the right direction.
Jac Mac
Old 03-15-2009, 02:11 AM
Ron61's Avatar
Post
Also you might try one of the big truck repair places.I got a bunch of stuff like that from the big Peterbilt repair place a few miles from my house when I was building my Cobra. They had a huge selection of almost every kind of grommets, lights, and anything else odd that I needed.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 03-15-2009, 03:58 AM
http://www.mcmaster.com
This site is amazing. And they deliver fast. They have hudred of grommets and you can shop from the comfort of your home.
Brian
Old 03-15-2009, 06:13 AM
PACER Wire and Cable. SkinTop 2 Liquid tight connectors. I use them all the time in my boat building.
Old 03-16-2009, 10:39 AM
Cobra Make, Engine: JCF supplied the body,frame,and some of the driveline-I completed it to be a very accurate 289 slabside
Default Grommets
The best source for grommets and other parts is Restoration Specialties & Supply,Inc. http://www.restorationspecialties.co...og%20ebook.pdf
They have grommets with groove widths up to 1/4".
Old 10-29-2009, 05:27 AM
Cobra Make, Engine: SPF 2592, Shelby alum. 527
Resurrecting an old thread. I found this site and thought someone might find it useful.
They have quite a selection; groove widths up to 5/8".
http://cableorganizer.com/grommet/
Rodger
Old 02-23-2012, 03:59 AM
Foud this website with full range of grommets
Desk Grommets, Power Data Grommets, Floor Access Grommets
