Old 03-25-2009, 10:33 PM
Send a message via AIM to Rolling Thunder
Default Tranny Swap
It's been over 8 years since I bought my Contemporary, but I finally got a 5 speed Tremec to put in place of the top loader 4 spd. Anyone have any tips/suggestions/helpful hints to make the R&R go smooth?
Anyone in the Cinci, OH area have some experience with this install and some spare time sometime in the next few weeks, I'd be willing to accept some assistance. :-)
Thanks, Keith
Old 03-26-2009, 12:46 AM
PANAVIA's Avatar
what Bellhousing did you get, which tremec >?
Todays Word: *interdependency* !! also --what engine >?
Old 03-26-2009, 01:18 AM
legenmetals's Avatar
Hi Keith, I have one in my 427 contemporary and it works great. My car had this transmision in it when I bought it. When a new clutch was needed I realized that the tranny cannot be removed without pulling the engine first.The other option is modifying the crossmember so that the crossmember can be removed allowing the removal of the transmision without pulling the engine. I have a lakewood bellhousing and hydraulic clutch and if I remember right I think it has a spacer plate between the bellhousing and the transmision. I will try and get some pictures posted of my installation so you can get an idea what you are up against. The hole for the shifter lines up with the tunnel. Finishline sells a shifter that bolts right on and looks original. Your drive shaft may need modifying also. Don't forget about correct pinion angles when modifying your crossmember.
Old 03-26-2009, 05:17 AM
mickmate's Avatar
That's a good looking example you have. Doug has a few good pictures of his removable tranny cross member if you need some. Also if you need them I have the flanges here to make his cross member removeable before we discovered it already was. The clutch is a bit of a trick with such tight constraints within frame rails. Forte has a slick arrangement with a drilled and tapped block welded right on the side of the Quicktime bellhousing for a heim jointed CNC slave cylinder. Let us know if there are any questions or pics required.
mickmate
http://www.actoncustom.com/
Old 03-26-2009, 05:32 AM
Hi Keith,
The Top loader has the same length and bellhousing bolt pattern as the TKO. I sell a FE input kit so you can use the same bellhousing and linkage with just a clutch disc change to 26-spline if you have a TKO-600. You would then just install a 31-spline yoke on the same driveshaft. The X-member mod would be the only change underneath. The speedo gear is different. Call me with any questions.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
Old 03-26-2009, 12:25 PM
Thanks for all the info. I hadn't thought about the crossmember being non-removable. Ugh. I wonder if I've got enough room to pull the engine forward to get enough clearance w/o having to remove it completely - I'd like to avoid removing the the header tubes which I think I'd have to do to take the engine completely out. I'll have to look this evening.
Modifying the crossmember sounds daunting. I would like to see pics.
Since my 351C is rather mild, I went with the older TR3550 instead of a TKO500/600. The input and output shaft spline counts (10/28) should be the same as the top loader. It's also my understanding that the Tremec will bolt right up to my current bellhousing.
