Like Tree2Likes
Old 04-14-2009, 07:44 AM
Originally Posted by undy View Post
...is someone who posts controversial, inflammatory, irrelevant or off-topic messages ... with the primary intent of provoking other users into an emotional response.
Well I, for one, would never even think of doing such a thing. Maura, after repeatedly frying the back of my ankle, I now carry a welding blanket in the car. Mostly for my passengers, as I don't really care all that much about me (but I do use it, when I can remember to reach behind the seat and pull it out). I also put them over the pipes when I pull in somewhere (like a car show) where there is the possibility that little kids will run up and touch them before I can stop them. My ceramic pipes cool down within a few minutes, but initially they can be upwards of 400 degrees.
Old 04-14-2009, 08:09 AM
JWilly's Avatar
Cobra Make, Engine: Superformance, Roush 402R and CSX 6029
I don't know of any business that sells welding supplies near me (not that they don't exist, I just don't know about them). Anyway, what would be a good place to pick up a welding blanket?
Old 04-14-2009, 08:16 AM
That one that you see in my hand is called the "Velvet Shield" and I got it from toolfetch.com
http://www.toolfetch.com/Brand/Stein...s/STI31646.htm
Old 04-14-2009, 08:31 AM
Did you buy 2 of them (one for each side), or buy one and cut it in half?
Old 04-14-2009, 08:32 AM
I bought one and then cut it with scissors. It's very easy to cut.
Old 04-14-2009, 08:35 AM
Thanks. I'll order one and do the same.
The side pipe temp is about 400F, closer to the engine where the headers are is about 700F.
Old 04-14-2009, 08:37 AM
CobraDan's Avatar
http://www.thepipesarehot.com/sleeveimg2.html
http://www.backdraftparts.com/shopexd.asp?id=68
Dan Wulff
Old 04-14-2009, 08:50 AM
The last really good burn I got was from the aluminum radiator tube that heads over to the surge tank. No, it doesn't get to 400 degrees, but it will burn the crap out of your forearm if you're thinking about something else when you stick your arm down the front of the engine.
Old 04-14-2009, 10:37 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
Summit sells the Velvet Shield in a 4' x 6' sheet, which is enough to do a couple of cars. Cut a piece as long as your seat, fasten it under the rail (or the seat if it's bolted to the floor) roll it out and cut it off at the bottom of the pipe. Roll it up and stow it between the seat and the body. If your carpet is black you won't even notice it.
Bill Stradtner
Old 04-14-2009, 12:01 PM
Cobra Make, Engine: Butler, 351W
Does anyone have any ideas as far as removing burnt nylon from the side pipes? I have been told that "easy off" is not a good option.
thanks
Leo
Old 04-14-2009, 12:04 PM
thanks
Leo
I had burned-skin stains on my ceramic coated pipes <seriously>. It was more noticable than you would think, too. Surprisingly, 409 Spray Cleaner removed the nasty skin stains and left no after marks.
EDIT -- BTW, somebody is bound to suggest lacquer thinner. Over the years I've seen competing posts when it comes to lacquer thinner and ceramic coated pipes. Some say it works great for cleaning them up, some say it ruins the finish. I'd like to know what the true answer is.
  #33 (permalink)
Old 04-14-2009, 12:21 PM
JWilly's Avatar
patrickt and CobraDan...Thanks.
  #34 (permalink)
Old 04-14-2009, 01:40 PM
Cobra Make, Engine: jbl
a little canola oil either on the skin or pipes helps in the detachment phase.
  #35 (permalink)
Old 04-14-2009, 05:32 PM
Cobra Make, Engine: Butler Racing/427 side oiler
well heres proof it does burn skin...my niece. and she was a trooper about it.
Still sucks though.
  #36 (permalink)
Old 04-14-2009, 05:37 PM
DocDirk's Avatar
Cobra Make, Engine: West Coast-Ford Performance Solutions 533 BB
Default "that still sucks"
Was that burn with or without sidepipe heat shields? I wonder if they work well enough to reduce the risk of such burns? My shields do get pretty hot but feel more like hot coffee in a thin cup. Then again, I have no very long runs in the car yet.
The government giveth and the government taketh away..... if our rights are not God given then they're subject to revision!
  #37 (permalink)
Old 04-14-2009, 05:40 PM
Default Magic Goo
Here's what you use. It's magic goo....
  #38 (permalink)
Old 04-14-2009, 05:43 PM
that burn was without shields.
she is short (obviously) and got out resting her leg momentarily on the pipe..about 5 min later she says"uncle....the cobra bit me" poor thing ...NEVER again! ran cold water on it for 15 min and then she went home with Dad...this is the picture from the next day
  #39 (permalink)
Old 04-14-2009, 07:52 PM
Ibr8k4vetts's Avatar
I almost always wear shorts in the Cobra, That way I feel the heat before I get the burn It has worked for 8 years with no burn
Mike Z
  #40 (permalink)
Old 08-31-2011, 10:30 PM
Cobrajames's Avatar
Cobra Make, Engine: SPF 2303, Titanium Silver, Roush 427 SR/TW, AED Carb, Firefly Sides, TKO 600
Default First Snake Bite, today
Originally Posted by Got the Bug View Post
Opening the hood latches is also how I got bitten...wearing shorts that day. Also, melted the sleeve a fleece jacket checking under the car one day.
Opening the hood latches after a drive was my method of getting broken in. Wasn't paying close attention, but I think I will in the future.
