Old 04-27-2009, 09:32 AM
undy's Avatar
Default Forgetfull ol' farts and toggle switches
I ran across these and couldn't resist ordering a set. Every year, in the spring, there's at least 1 or 2 toggle switches that I can't remember what they did/do..
www.augerresources.com/switchlabels.htm
Too many toys?? never!
Old 04-27-2009, 10:39 AM
Not a bad idea after i had just waxed my car and hit the windsheild washer toggle instead of the headlight.
Old 04-27-2009, 11:03 AM
Cobra Make, Engine: jbl
hope your ciphering brain cells don't take a vacation. i went the old label maker route and used plain english.
good idea though and looks good.
Old 04-27-2009, 02:59 PM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
I was gonna use clear P-touch labels with white lettering but these look pretty good. Thanks.
Bill Stradtner
Old 04-27-2009, 03:34 PM
Default C'mon!
Jeez guys, it's only three, or four at the most, switches. If you can't remember them then that's pretty sad....
Old 04-27-2009, 03:41 PM
RodKnock's Avatar
+1. Also on my car the fuel switch is under the fuel pressure gauge and the fan is under the temp gauge. And if you don't drive at night or through any moisture, then who cares about the light switch and wipers.
Old 04-27-2009, 05:55 PM
undy's Avatar
Patience grasshopper, your time approaches ..
Old 04-27-2009, 07:54 PM
55312's Avatar
LOL
How often do you use your wipers? Your heater? I haven't hit the right switch when I've needed one of those in 5 years!
Tim
Old 04-27-2009, 09:11 PM
twobjshelbys's Avatar
I reached for the lights and loved it when I hit the fuel pump switch...
Old 04-27-2009, 09:47 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Red face
Am I the only one who carries a copy of my dash switches xeroxed from the owner's manual?
Old 04-27-2009, 11:47 PM
FUNFER2's Avatar
I like the air compressor ! lol
Kevin
Old 04-28-2009, 06:08 AM
Ron61's Avatar
Post
Those are nice. My worst problem was remembering which was the fuel pump switch and the car would run about 1/2 block with the pump off before stopping. It is embarrassing to be sitting there trying to get it to start and having people stop and tell you what a great ride you have. I finally marked mine with a very small tab that had ON on one end and OFF on the other.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 04-28-2009, 10:20 AM
Cobra Make, Engine: SPF #1019
I kinda like the idea of my dash switches be unlabeled - it adds a tiny bit of security: if some would-be theif got her started but couldn't get far due to not knowing which switch was the fuel pump (assuming I had an electric fuel pump on a dash switch).
Old 04-28-2009, 10:22 AM
For those of us with mechanical fuel pumps, we could just label a dashboard switch as "Fuel Pump" and have it ground out the ignition when switched "On."
Old 04-28-2009, 12:31 PM
Just get a tatoo on the inside of your right wrist with the pattern...
The chicks will dig it.
Old 04-28-2009, 03:13 PM
Sharroll Celby's Avatar
Back in the 60's, the switches were probably labelled with one of those "DYMO" embossed tape machines, where you turned the wheel to imprint the label.
I still have mine from when I was a kid. I even have some of the tapes as well!
Of course it's REAL! You are NOT imagining it!
We don't want a bigger government; We want a government that does a few BIG things, and does them right.
If you think that you can cut it, if you think you got the time, they'll only give you one chance, better get it right first time. 'Cause in this game you're playin, if you lose you got to pay. And if you make just ONE wrong move, you'll get BLOWN AWAY!
