January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-09-2009, 03:59 PM
Banned
Cobra Make, Engine: ERA 428 FE 4-speed CR "TL" heavy spline
Default Identify, Please (air cleaner parts)
Following is a picture of an Air Cleaner (top and bottom) that I received when I purchased my Cobra a few years ago. It's probably really old. - possibly from the 1960's.
1. Is this an original 'part' for a real Cobra or is it an aftermarket item?
2. I'm assuming that it's for a 2-4 barrel setup or perhaps not with the one hole in the middle of the bottom section (each section is 21" by 10" [huge air cleaner])?
3. Any idea where to get the middle part - the Air Cleaner element?
4. Are there other parts missing - this is all I have?
I'm thinking about doing something with it in the future, just wanted to know some history, if available from someone here. Although, it's surprisingly heavy material.
Thanks.
Old 06-09-2009, 04:11 PM
FWB's Avatar
FWB FWB is offline
its a reproduction of the 2 four bbl air cleaner made with a base to fit a single 4.
i have one too, K&N makes an element....# C207AB
there's a flat piece of steel missing it has a hole in center to attach to the carb stud in the airhorn, and two studs to tighten the air cleaner down. i will look to see if i have the bracket, i'll make a drawing of it
Fred
Banned
I'd love to help you, but I can't see anything beyond your wonderful avatar.
-Dean
Old 06-09-2009, 04:20 PM
FWB's Avatar
FWB FWB is offline
here's where to get the bracket...........
http://www.cobranda.com/inhakitforov.html
Old 06-09-2009, 04:29 PM
Banned
Thanks.
What about the air cleaner element that fits between the top and bottom?
Nevermind - I see you also posted that information, thanks again.
Old 06-09-2009, 04:33 PM
Banned
Fred
By the way, Fred - do you have one on your Cobra? Why are they so heavy and is there any real advantage to using one or is it just a good look and functional?
Old 06-09-2009, 06:37 PM
FWB's Avatar
FWB FWB is offline
i have a dual 4 bbl one on right now, but only because i can't find anything better to fit under the hood. they are restrictive for flow purposes, so if you can get a bigger filter element under the hood use it. the # i gave you was for the element i can use under my hood. its about 1.75 inches thick. K&N does make a thicker element the same oval size. i think summit racing has them shown on their web site. they are so heavy because they are cast aluminum.
Fred
Old 06-10-2009, 08:59 AM
Banned
Thanks, it sure has a nice look.
