Old 07-21-2009, 05:03 AM
DougD's Avatar
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
Default Source for puke tank hose?
Does anyone know the part number and source for the clear hose used to plumb the oil puke tank to an Aviaid pan on an FE? Does it need to be high temp? What are you using? I'm rerouting mine and can't find anything locally. Thanks in advance.
Doug
CSX4068
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
Old 07-24-2009, 01:25 PM
I used the clear hose years ago. I believe I purchased it at a pet store where it was sold for use with aquariums. I've also seen it at Home Depot in the plumbing section.
Within a few months of use, the clear hose turned yellow and started to harden. The heat and exposure to oil vapors probably caused that to happen. After about 2 years, I removed the puke tank and didn't use it for about 10 years.
This spring I re-installed the puke tank and used black rubber hose. I like the look of it better than the clear hose.
David
Old 07-28-2009, 05:28 AM
DougD's Avatar
601HP
Aquarium tubing? Seriously? I thought something intended for automotive applications would be used.
I'll check Home Depot tonight and see what they have. Thanks for the leads.
What's everyone else using?
Am I the only one trying to use clear hose?
Old 07-28-2009, 05:59 AM
Ron61's Avatar
Post
I used black hose that I got from NAPA. That was years ago and it stood up very well.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 07-28-2009, 10:00 AM
Jamo's Avatar
Super Moderator
Clear hose...more original looking with the yellow patina. Added as much as 23hp above 5,000rpm.
Jamo
Old 07-28-2009, 03:36 PM
Xavier's Avatar
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
Check out McMaster-Carr.com, look at the "tubing" (type it in within their search area). You can basically select the product you need on the right of the screen by each requirement, temperature, color, wall thickness etc.
What you need is Ultra-Clear PFE rated up to 450 degrees and is about $1.50 a foot. A nice bend radius..but there are many others to choose from there. PFE is what I would recommend for chemical durability, temp and abrasion. Can bend in radius as well.
http://www.mcmaster.com/#tubing/=2y3j5d
