November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-03-2009, 11:47 PM
LMH's Avatar
LMH LMH is offline
Default What Foam for Fiberglassing
Hey all
I'm going to make a glovebox for my dash. I'm was planning on using a foam block and making a "plug", then covering that with fiberglass/resin to make the box shell. Anybody know what kind of foam I need to use that won't react with the resin?
Old 08-04-2009, 05:26 AM
http://www.fibreglast.com/showproduc...+Foam-146.html
Old 08-04-2009, 09:05 AM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Larry,
Mr B. hooked you up with foam and another option for you is sheetmetal. Use spots of hot glue like rivets on inside or overlaps so finished part is cleaner. A little automotive wax makes plug removal a snap. Posterboard or even file folders work but will stick to your masterpiece, tear loose and hit with another layer of glass as you just want the shape 1 time. Jeff C
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 08-04-2009, 09:12 AM
bobcowan's Avatar
I was watching one of those powerblock shows. They were making fiberglass flares on a mustang. They used that green foam that florists use for a plug, then layed 'glass over that. It was real easy to shape and get a fairly smooth surface. Came out pretty nice.
Old 08-04-2009, 09:44 AM
vettestr's Avatar
Don't tell anybody but this sticky stuff is really pretty easy to work with. You can cheat and use about anything if you keep the resin off whatever with aluminum foil or clear food wrap. Even Styrofoam will work but if you get a hole or it gets on foam it will just melt before your eyes. WHAT A MESS !
footnote to self..... 200 MPH tape does not work, glue melts !!!!
Jeff Classic
Old 08-04-2009, 10:47 AM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
When i built the TVR front air dam plug i use regular construction pink foam worked fine for me..
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
Old 08-04-2009, 11:30 AM
LMH's Avatar
LMH LMH is offline
Nice job map!
Thanks for the info guys. I have a fair amount of fiberglass exp, so I don't think this will be something I can't handle.
