Old 09-05-2009, 11:06 AM
Tom Cimino's Avatar
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
Default Cast aluminum cleaners?
Does anyone make an aluminum cleaner that will restore an old manifold to original brightness? I'm currently looking in marine supply stores. If I can't find something, there's always bead blasting.
Old 09-05-2009, 11:42 AM
I take it this was a polished manifold? If so, and it's not too bad, I'd use Mother's Aluminum Polish. If it's in bad shape, then a cotten wheel on a drill, or even a small one on a Dremel, WITH jeweler's rouge would be a good start, after that, the polish above.
If it's a natural or even gray surface, then just use Brake Klean and that's as good as it's going to get unless you want to polish it. That would be a lot of work,especially if it's still on the engine.
Old 09-05-2009, 12:47 PM
Tom Cimino's Avatar
It's an old Elelbrock, still as cast. I want to bring it back, so it matches my Edelbrock heads.
Old 09-05-2009, 03:27 PM
Check this out:
http://www.eastwood.com/buffing/meta...ith-clear.html
Old 09-06-2009, 06:54 AM
Beretta92's Avatar
To remove stains and clean try Eagle One Etching mag cleaner
http://www.eagleone.com/pages/produc...=1001&cat=5006
Then blast with walnut shells or glass bead, obviosly it has to be removed from your car.
This will leave it like new as cast.
Old 09-06-2009, 11:25 AM
I have the same problem and i found this. thinking about ordering it but have not done so yet.
http://www.metalwax.com/METAL%20CLEANER.htm
Old 09-06-2009, 06:50 PM
Tom Cimino's Avatar
That's what I'm looking for. Thanks for the input. The manifold has not been installed yet.
Old 09-08-2009, 03:15 PM
Ditto on the Eagle etching mag cleaner. Used that on my wheels. Much more effective than brake cleaner for "natural finish" aluminum. Just make sure you use it in a well ventilated area and I would suggest wearing gloves (preferably nitrile).
Old 09-08-2009, 03:47 PM
FrankJohnson69's Avatar
Cobra Make, Engine: ERA-722, Pure Street in BRG
And don't use it on concrete that you care about.
Old 09-08-2009, 05:00 PM
Banned
Ditto on the Eagle etching mag cleaner...Just make sure you use it in a well ventilated area and I would suggest wearing gloves (preferably nitrile).
This stuff is nasty. It works great, but it's nasty.
Old 09-08-2009, 05:01 PM
Tom Cimino's Avatar
I picked up a bottle of Eagle etching mag cleaner. My manifold is still at the machine shop, so I tried it on a 31 year old American Vector wheel on my '77 F150 4X4.
The good news, it seems to work really well. The bad news, now I have three more wheels to do.
Old 09-08-2009, 05:26 PM
i have the same problem. I had a leak in he radiator and it stained the valvecovers and intake. I saw this but have not decided on it yet.
Old 09-08-2009, 05:37 PM
Chaplain's Avatar
Cobra Make, Engine: Everett-Morrison, 429CI
Back in the day used to wet sand aluminum with kerosene and progressively finer emery paper. Final polish on buffing wheel.
Old 09-09-2009, 07:15 AM
Clois Harlan's Avatar
Powder Coat it for about $20!
"Let's roll"
"Be part of Something Good
Old 09-09-2009, 09:28 AM
NAPA sells a product for cast only that I'll have to look at when I get home. It worked OK but not like brand new. I have a fairly new manifold that had some gas stains on it.
I decided to use a paint product (which also is home) I believe called Durablast Aluminum. Its made for high heat and also finished it off with high heat Clear Gloss. Totally happy with the results. Its been over a year and still looks like it did on Day 1. Very little difference from bare aluminum.
