Like Tree2Likes
Old 10-01-2009, 07:59 AM
SunDude's Avatar
Default What is the drag coefficient of a Cobra roadster?
Does anyone know what the coefficient of drag (cd) and frontal area (sq.ft.) were on an original 427 Cobra roadster?
Old 10-01-2009, 08:02 AM
Gutt feeling based on knowing the numbers for some other cars.
.41 or higher, a real brick.
Old 10-01-2009, 09:31 AM
RodKnock's Avatar
Less than 1.
Old 10-01-2009, 10:23 AM
Here's an example of what I'm talking about "gutt feeling". First and Second generation Mazda Miata. Wheel base, size, weight all comparable to a Cobra. MUCH smaller frontal area, looks like it would have a pretty good CD. In fact Miata's are .38 which is pretty high, much higher than many modern cars. Therefore, Cobra's having even more frontal air and a much larger grill opening couldn't be any better. A .41 estimate is likely cutting them some slack!
Old 10-01-2009, 10:46 AM
I've seen more than a couple of calculations that list it at .42 -- a brick it is.
Old 10-01-2009, 11:26 AM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
All you have to do is ride in one to know that air does not go over or around the car very smoothly. Keeping a hat on is all but impossible. The steep windshield (by today's standards) does not help.
Bob
Old 10-01-2009, 11:33 AM
A Hummer is about the only modern car I can think of off the top of my head that it beats. The lowly Prius comes in around .27, if memory serves.
Old 10-01-2009, 11:48 AM
Forgive my ignorance, but I take it the lower number is more aerodynamically slippery?
Hard to imagine a Cobra worse than a Miata based on the pic above. Just look at the giant side mirrors on the Miata and compare to the bullit pointy side-mirror on a Cobra.........LOL.
Old 10-01-2009, 11:49 AM
Yes, lower is better.
Old 10-01-2009, 11:53 AM
Default ... and it's harder than you think to tell just by looking
Most people would bet that a Lamborghini Countach would not have the same CoD as the Cobra, when actually they're very, very close.
Old 10-01-2009, 02:33 PM
Silverback51's Avatar
It's better than a 4 X 8 sheet of plywood, but not by much.
TheExtreme likes this.
John Hall
Old 10-01-2009, 04:02 PM
greg schroeder's Avatar
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
I figured it out a while ago based on rear wheel HP on a dyno and then HP loss at speed using a G-tech compition meter. It does look to be over .4 as mentioned. The usable HP at higher speeds has a huge loss from resistance. Over 120 or so mph it becomes a real challenge and even seems to require diffrent jeting there's so much load.
This is third gear with a few charts and assorted changes. It came out to be about 100 HP of energy loss around 110 mph. The faster you go the loss becomes exponential. The car on the dyno was making about 475 at the wheels when it made about 340 or 350 in motion of usable power.
Here's a formula.
http://www.gtechprosupport.com/support/AeroDragCalc.php
off idle drag pass, DA 750ft.
Old 03-22-2012, 10:51 AM
Bxx1's Avatar
Perhaps its those wiide tires.
Old 10-01-2009, 06:23 PM
ZOERA-SC7XX's Avatar
If I remember correctly, that's why Shelby developed the Cobra Daytona coupe. The roadster just didn't want to run much over 160 mph.
Old 10-01-2009, 06:24 PM
Just to help keep a VERY complex subject simple, I figured a Miata would be a good comparison. Similiar size, weight, shape with smaller frontal area.
BUT Patrickt brought up an interesting comparison with the Lambo, which apparently has very little frontal area and yet a CD similiar to a Cobra??
Which reminds me of the testing Shelby did when he first started working on the Ford GT-40. Overheating, terrible drag, low top speed. Due mostly, as I recall, to the many "air scoops" here there and everywhere. Which may be the Lambo's problem, big ass air scoops.
Thats some impressive work Greg!
Old 10-01-2009, 06:43 PM
eschaider's Avatar
Default Cobra Drag Coefficient
Here is some data out of the Bosch Automotive Handboook
We are probably pretty close to the entry for "Typical Roadster" with a Cd of 0.55
Sooo, that puts us in about the same class as a bus! Good news is we are not as bad as a truck.
Ed
tuska likes this.
Old 10-01-2009, 07:32 PM
lovehamr's Avatar
Stolen Avitar
Ed
WoooHooo!!!!!
BTW, if memory serves, that huge CD for the Countach was when it was fitted with the huge rear wing not shown in the above pic.
Steve
Old 10-03-2009, 08:00 AM
mdross1's Avatar
Put enough horsepower to a brick it and becomes very fast.
Old 10-03-2009, 11:15 AM
That defines the F4 fighter too.
John Hall
Old 10-02-2009, 08:11 AM
Cobra Make, Engine: Everett-Morrison
Default just to stir up the pot a bit.........
I am by no means an engineer, but based on what all of you have said, which BTW, sounds very credible and logical to me, I just couldn't help thinking of Dick Smith's car reportedly going 198mph. I just find it too difficult to accept and believe that Dick was actually able to drive his car that fast.
As mentioned, if it takes a substantial amount of hp just going 110mph, and at 160mph, the Cobra, due to its shape, is hitting the aerodynamic wall, then how could it be possible, back in the 60's, that Dick could go faster by almost another 40mph?? Morris Clement in his well engineered car with air splitter, wing, flat belly pan, and tons of hp, I haven't heard that even he has been able to reach the speeds claimed by Smith. Something just doesn't add up.
I'm not trying to take anything away from Dick, but physics is physics. If I'm missing something important facts, I'd like to know.
Display Modes
