03-06-2010, 01:02 AM
ni
Cobra Make, Engine: DRB (australia)
chrome falling off lake pipes
Hi Guys (inc DRB Australia !!!) the chrome is peeling away from my lake pipes, Had them 3 yrs now, there is the old chicken wire effect on the chrome plating, and there does not appear to be any (copper) or nickle primer on the pipe itself, starting to rust, Has anyone else had this problem, and how did you rectify it. pz help as to re-chrome is a costly process. Thanks ---Mic
03-06-2010, 09:51 AM
Ne.
It sure sounds like a crappy job by the plater !
Did you pay for the work or did you get these second hand ?
Either way, someone got screwed !
I would prefer highly polished stainless steel over any,.... coating. Check out mine.
Beautiful and will never rust.
Kevin
03-06-2010, 06:19 PM
Senior ClubCobra Member
Agreed. That's why your local muffler shop switched to tires and brakes after car companies switched to stainless steel exhausts on autos.
Mild steel, heat, and moisture equals rusted out exhausts.
03-06-2010, 09:10 PM
MI
Crappy plating, no other reason. Semi truck stacks get as much heat & WAAAAY more hours on their chrome stack pipes & they can last for many years if the chrome is good. The imported Chinese chrome is all crap on the truck stacks - lucky if you get 6 months out of them. Double nickle & chrome & do it right, it'll last for many years.
I talked with a guy at MATS last year that had his chrome stacks on his truck for 23 years & they still looked good.
03-06-2010, 10:58 PM
ni
chrome pipes
lovely job Kevin, my pipes were from DRB Australia must have done a sh-t job.  mind you the agency over here. well.) I've now got sus the best rectification to fix the issue here. Thanks---Mic
03-07-2010, 09:15 AM
sc
Cobra Make, Engine: Unique 351w stroked 396
polished stainless sidepipes
Hi Kevin ,
The side pipes you have in polished stainless are really nice . Would you mind telling me where you purchased them . I would love to have a set like them on my car . I keep having to polish and re chrome to often .
Traveler
03-07-2010, 09:56 AM
Ne.
Hello Rick & thank you.
We make them ourselves. After seeing what's out there, I wanted higher quality and something that would last the life of the car,......or me. lol
304 stainless
No glass pack to blow out.
No coating to dull out or flack off.
No rusting.
Easy to clean & polish.
Look how the collector and the turn out, slide in between the muffler and the outer shell, for a nice & tight clean fit. Plus, it requires on very small tig weld.
And,...beautiful.
I gained 6 hp at idle, on the chassis dyno.
Send me an email & I'll give you details and many photo's. I'll send you my number also.
cobrakev@galaxycable.net
Listen to the sound oh these pipes on my cobra. Not high rpm's and clutch slipping but, they sound great. Although it's a open muffler, listen at the idle, I don't believe their too loud, even my wife says so. lol
http://www.youtube.com/watch?v=3fuuIbkJjwI
(MY OLD MILD STEEL AND DULLED OUT CERAMIC COATED EXHAUST)
(CLEAN TIGHT FIT OF COLLECTOR INTO MUFFLER AND TURN OUT))
(UN-RESTRICTED 3.5" MUFFLER. NO MUFFLER WELDING TABS INSIDE TO BREAK LOOSE AND MAKE NOISE)
(POINTS & STARS WELDED TO DIRECT FLOW)
Kevin
03-07-2010, 10:04 AM
Ne.
I love a good chrome job.
I have several chrome parts on/in the car but, not on the pipes and never will. A few people have had good luck but, not many. I drive my cobra too much to have chrome.
With the cobra's side pipes being so low to the ground and the tires throwing pebbles, you'll get chips with chrome, which means,..... rust.
With stainless, it's not an issue.
Kevin
03-07-2010, 03:03 PM
Originally Posted by traveler
Hi Kevin ,
Traveler
Stainless Works and Stainless Specialties both make stainless sidepipes for Cobras. Send them yours and they will copy it.
09-23-2014, 06:43 AM
Hello Kevin,
Can you tell me how to purchase your side pipes?
Thank You
Henry
09-24-2014, 03:39 AM
Originally Posted by hstronski
Hello Kevin,
Thank You
Henry
He hasn't posted here in over a year...
Too many toys?? never!
09-24-2014, 05:04 AM
SA
Which way have you got the flow? Into the louvers or across them.
My muffler shop tells me to flow across so as not to burn out the glass mat.
JD
