Go Back   Club Cobra > General Discussion > All Racing Talk
  #21 (permalink)
Old 07-28-2012, 07:06 PM
Default Tires
From post #3:
I think what you found so far improves your problem(s) by 98%.
Does Hoosier make a compound for your usage? The only problem I had with TD's was circumference differences, giving stagger. Adjusted by over-inflating the small side and heat application. The runout was always less than G'years.
Possibly yours can be trued by that's a lot to shave.
Japanese tires are always very true but I don't know what you can use.
They allow Hoosier TD's but they are much smaller and may not have the grip of Goodyears I don't know for sure just what I have been told. They also allow an Avon vintage tire but again I don't know much about them other than I believe they are smaller than the GY. The GY tires did really well in an autox I attended. I beat an experienced guy in a Z06 on Hoosiers or Kumho's and a GTR on Hoosier A6's so I am happy with their handling just not max acceleration. I agree with you about the Japanese tires, their quality control is excellent, only Hoosier A6 and R6 are better and of course any Michelin.
I will see what AVON has available in vintage legal sizes. I wonder if this problem is similar to what the drag guys get when tire shake occurs.
The drive shaft joints might not have been clocked correctly when they welded the yoke. I am going to take a hard look at that tomorrow.
  #22 (permalink)
Old 07-28-2012, 07:10 PM
Default Tire hitting
Originally Posted by MOTORHEAD View Post
3170: "only shows up under extreme torque"
Had a similar situation in a bdr. "go" pedal goes down, rearend goes down (squats), tire hits body/frame. Don't think tire would hit anything on an original/shelby/kirkham, but it's worth a look.
Ted
I am going to check for that as soon as I get the wheels off, you never know what is going on when things get violent.
  #23 (permalink)
Old 07-28-2012, 07:25 PM
Sorry-I have no answers but plenty of questions:
Did you find zero wear in the all the u-joints? That's a ton of power you hit them with.
Are you using mag Halibrands and are the drive pin holes getting oblong?
Hoosier Quick Times (if they don't have run-out issues) may be good for Auto-X?
Maybe discuss your findings with Roger and get his recommendations??
Chas.
  #24 (permalink)
Old 07-28-2012, 08:38 PM
Default Questions
U joints are still tight but they have very little time on them 4 autox runs and about 8 track laps
I am using aluminum Trigos, I am afraid of my 47 year old Mag Halibrand's
I have never really had a problem with pin drive hole elongation because I put my wheels on very tight (big lead hammer and anti seize)
The Hoosier A6's are the best autox and track tire out there, but are not legal for vintage, neither are QT's
Called Roger Friday, he thinks it is a drive train issue and might be right,
I did not tell him the torque numbers though which might have changed his opinion
  #25 (permalink)
Old 07-28-2012, 10:30 PM
Barnsnake's Avatar
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
Since the problem is primarily when significant torque is applied, I would take a very long look at the mounting of the rear-end center section. If it is rotating the pinion upward under acceleration the mis-matched driveshaft u-joint angles would cause exactly the symptoms you describe.
Jim
A Gnat! Quick, get a sledgehammer!
  #26 (permalink)
Old 07-29-2012, 05:54 AM
mickmate's Avatar
Hey Bruce what did Brian use for a bushing material? That's been around for a minute or two and hasn't just done the church run on Sunday.
mickmate
http://www.actoncustom.com/
  #27 (permalink)
Old 07-29-2012, 06:52 AM
Default Pinion angle and bushing material
I agree that could be the issue, the cradle uses the same bushing that the original uses a rubber bushing with a threaded insert that takes two 5/8" bolts one on either side. If the bushing were completely gone (it isn't) the nose could go up a maximum of .6" before metal to metal contact. I am going to put a hydraulic jack under the the front of the rear end and try to force it up today to see how much movement I get. The bushing is a sleeve within a sleeve it has an outer sleeve that is approximately 1.75" in diameter and then the inner which is about .93" tapped for the two mounting bolts that come in from the sides of the double shear mount in the car.
  #28 (permalink)
Old 07-29-2012, 08:06 AM
Default Senior Moment
I just remembered how the mount is configured, what I described is incorrect.
There are two metallastic bushings pressed in on each side of the mount, in the center is a floating threaded sleeve that is positioned via a 90 D. 1/4" threaded hole. The mount has a clearance hole that is used to position the sleeve with a 1/4" bolt to start both main mounting bolts, it is then used to keep the sleeve from rotating while torquing the main mount bolts, after torquing you remove the 1/4" bolt.
The transmission and rear end are not inline in a top view because the engine is offset to the right but is supposed to be flat in the side view, if the front of the diff moved up it could put the U-joints slightly out of phase. I thought about making the front mount solid but did not because I did not want to cause drive line failures from shock loading.
  #29 (permalink)
Old 07-29-2012, 04:20 PM
The bad news:
The flywheel has dings, cuts and scrapes all over it both front and back, I could not figure out what caused it because there was nothing in the bell housing. I then noticed that a piece broke off the clip-in Ford throw out bearing on the back side it is cast iron and pulverized everything in there.
The really bad news I am not sure this caused the vibration because the engine doesn't vibrate in neutral.
I will have to pull both seats, the tunnel, front engine mounts, drive shaft, transmount ,
bell housing, clutch and flywheel to get the parts out. I then need to find a new Magnum force flywheel and maybe a clutch if it is damaged.
All the mounts and U joints appear to be in good order I aired the tires to 50 PSI and put them in the sun so that they could find the roundness God. I am going to up the high speed bump adjustment on my rear shocks in case the problem is in the tires other than that I don't know what to do. If I can't find the right flywheel I may not be able to run.
  #30 (permalink)
Old 07-29-2012, 05:47 PM
My method exactly.
Lykins can help you get the clutch you want.
Chas.
  #31 (permalink)
Old 07-29-2012, 05:53 PM
If you get in a bind needing a flywheel or clutch, let me know....I can get pretty much anything and everything.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
  #32 (permalink)
Old 07-29-2012, 07:12 PM
Default Clutch
Brent,
Thanks, I will pull it apart tomorrow to see what is broken and what I need, I'll let you know if I can't get the parts because if I can't I will need a clutch, flywheel and throw out bearing. I am really running out of time, have to haul it to Laguna Tuesday after next.
  #33 (permalink)
Old 07-30-2012, 06:39 AM
Where are you located? I have access to warehouses on each side of the country and can get stuff drop shipped to you...
  #34 (permalink)
Old 07-30-2012, 07:04 AM
Cobra Make, Engine: SPF 239
Hey Bruce,
I sure am sorry to hear about all this. In reading all the details (good work) I would think the flywheel and clutch issues are a resulting failure but not causal. To me it sounds like the drive line is flexing at the extreme end of the load scale. You are stressing the thing far past the level mere mortals can dream. I would be looking at the trans, trans mounts, diff mounts, and rear end cradle. I wouldn’t be surprised to see a (partial) fatigue failure somewhere. Maybe at the cradle to main frame rail? Something in the driveline is moving out of alignment under (big) load resulting in a vibration.
Jason
  #35 (permalink)
Old 07-30-2012, 08:34 AM
Default Parts
Brent,
I am outside of Fresno Ca, I appreciate your offer but found the a flywheel at McLeod this morning that matches what is in the car, they are in California so I should have it by Wednesday AM. I started at 4:30 AM and had the flywheel out by 7:30 worst part was getting the starter out with those #16 oil lines in the way. It seems the $#@@#$ zerk fitting unscrewed from the Ford throwout bearing and destroyed the flywheel spokes and even part of the starter mounting flange, it looks like somebody shot it with a 10 gauge using double 00 buckshot, hard to believe it could do that much damage. I am sure this is not the source of the vibration as Jason stated. I have looked at all the mounts involved and can find nothing broken or damaged in any way, I lifted the car using the front of the rear end cradle mount and it might have shifted up .060
All the U-joints also look and feel good. I am going to take my sun stretched Goodyears to have them rebalanced today and re-phase the left half shaft to match the right half shaft. I will also start at 26 and 25 PSI and increase the high speed bump in the rear, beyond that I don't know what to do other than pray and keep my foot out of it. I'll use the time I am waiting for the flywheel to do a thorough nut and bolt plus move my brake bias adjuster and radiator catch bottle (I had interference with both during the test).
Thanks to everyone for your input, this forum is a great source of knowledge.
If I find anything else I will post it but do not expect to.
  #36 (permalink)
Old 07-30-2012, 09:20 AM
Bruce-please try to have them shaved to true the runout-it's not helping.
Your plan and thoroughness is great. I appreciate your taking time to post results. It's invaluable coming from guys like you that are pushing the car's performance envelope and very educational for us slackers. Morris' build and testing was of very similar benefit-but you're doing it with an original. If that's a limiting factor of your car's performance, it hasn't shown it yet. Great accomplishments from both of you. It's what I come here for.
Thanks from me.
Chas.
  #37 (permalink)
Old 07-30-2012, 04:16 PM
Default Balance
Thanks from me.
Chas, I wish I could but the run out exceeds tread depth.
I took the tires in today and had them balanced on a recently calibrated Hunter.
left rear was 2.75 OZ off, Right rear was, 2.5 OZ off, RF was 1.5 OZ off and LF was 1.0 OZ off, so much for having them balanced at the track race shop.
Perhaps the imbalance coupled with the large torque load was enough to cause a stick slip in the tire and the resulting vibration, I hope so. At least something was wrong, I feel a little better about it now.
  #38 (permalink)
Old 07-30-2012, 04:38 PM
Yikes-didn't realize that! Damn G'year-if the Japanese, Brits, French, Germans and Italians can get them better than that, why can't they??For sure that's a major contributor to vibration.
But I don't think it knocked the zerk off...
P.S. If you don't mind-exactly how much power and torque does the motor make?
Chas.
  #39 (permalink)
Old 07-30-2012, 04:58 PM
Richard Hudgins's Avatar
Cobra Make, Engine: Porsche 928 S4
I am going to take my sun stretched Goodyears to have them rebalanced today and re-phase the left half shaft to match the right half shaft. .
Bruce,
Unless you have a spool rear end, the half-shaft phasing is a moot point as the relationship will change as you drive the car.
Of course I could be missing something here......
Best regards,
Richard Hudgins
  #40 (permalink)
Old 07-30-2012, 07:30 PM
mickmate's Avatar
The half shafts are splined as they change length in this suspension design. You can slide them apart and put them back together out of phase. Bruce mentioned them being out.
mickmate
Display Modes
