| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
09-24-2002, 04:32 PM
Aluminum racing jack
Guys,
Harbor freight has a real nice all aluminim racing jack for $199.00
I bought one after looking over the one that Joe R. had at Pocono.
Made in China but for the money you can't beat it. I would not use it as an all around shop jack but for the track it is perfect for tire changes and it only weighs 37 lbs.
Check it out at Harbor freight on the net.
Cranky
Photo Item Description Price
47246-0VGA
US GENERAL 3000 LB. CAPACITY ALUMINUM RACING JACK $199.99
09-24-2002, 05:38 PM
Great jack, have one.
A mod I made lets the handle go lower to get under the car and still pump.
I removed the roller that pushes the piston and replaced it with a smaller roller.
HAVING TOO MUCH FUN
Scott
09-24-2002, 06:57 PM
NJ
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
I purchased one of these jacks and I really like it. The instructions said nothing about this but when your jack arrives there is a plug that has a ball bearing "check valve" in it included in a plastic bag. You are supposed to replace the solid plug sealing the fluid reservoir with the plug having the check valve. Funny how much better the jack worked after replacing that plug. Also, the fluid reservoir was nowhere near topped off so that had to be done as well. Again, the instructions never mentioned that.
Hey, ls1ac, where did you get the replacement smaller roller? What you did sounds like a good mod.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
09-24-2002, 09:49 PM
Ca
Cobra Make, Engine: ERA 427 SC #004 (Original ERA?)
Cranky, Guys..Thanks!
I've been looking for an aluminum jack in this price range and just ordered it!
Pete C
Superheart, I may post you for more info if the "fix" is not obvious!
Drive it like you stole it!
09-25-2002, 10:39 AM
CA
Cobra Make, Engine: SPF - 427 Stroker
Price Club also is selling one for less than $200 - very nice...
NEVER LIFT
09-25-2002, 12:55 PM
Cal
I would only use the aluminum jobber when weight is a concern. If you are in a pit stop during a race and the jack man has to run around to do both sides of the car for example. Or if you're chase car with all the tools is getting pretty heavy in the trunk. For around the shop use, ou need to spend $300 just to get a decent steel floor jack, that goes low enough to fit under these cars, and has a good enough valve so you can lower the car slowly and controlled instead of the "on-off" valving of some of those cheap jacks.
09-25-2002, 03:08 PM
Mr. Fixit,
Isn't that what I said in my original post.
The only problem is that everyone wants to borrow it at the track because it is so light.
BTW If you have not seen this jack, the quality will surprise you.
Cranky
09-26-2002, 10:35 AM
IL
Cobra Make, Engine: ERA 454 S.O.
Here is the link:
Aluminum Jack
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
10-05-2002, 01:51 PM
FL
Cranky - two questions....
1) Does one need to possess a "Competition license" to purchase a "race jack"?
2) Is it available in a POLISHED finish for Waxers?
....just bustin' yur chops.....
Thanks - Great tip....I'm gettin' too old to carry my old floor jack around when I want to go mobile....
Regards,
Jeff
CobraJeff
ERA P 202
11-06-2002, 05:27 PM
TX
Cobra Make, Engine: ERA #642 521 CID Ford Racing A.R.E. Crate
Hey, you guys better check out ebay. Somebody had several they were trying to sell and I think the "buy it now " price was way less
than 199.00
David Dakruzer ( not Daracer)
11-06-2002, 10:19 PM
IL
Cobra Make, Engine: Bare Aluminum pre-Kirkham CSX4000 427 Stroker by Southern Automotive.
Christmas gift buying for husbands made easy!
Cranky,
Thanks for sharing the economical aluminum floor jack source with everyone. I couldn't justify purchasing a race jack at the usual cost, even though I wanted one really badly. My wife will be getting me one!
I have been to the eBay auction site looking at these type jacks, and my word of caution is BEWARE! Most of the jacks listed appear to be U.S. General brand jacks purchased from Harbor Freight and relisted at a marked up price. The shipping charged varies from $25-$58. Harbor Freight charges $5.95 shipping.
Fast Farmer
11-07-2002, 06:23 AM
Ca
I bought the Harbor Freight jack in early October and I love it! As SuperHeart warned, the oil reservoir was low and performance is greatly improved when one adds some hydraulic oil! Well worth the money...and yeah, I brought mine to the track 2 weeks ago and people do love to use it! Then again, I'm glad to share since folks have been so generous with me.
Cheers, Pete
11-09-2002, 01:12 PM
Superhart
Just got back from SEMA, I used a long nut. Drilled the center to shaft size. Started with two nut for a test fit.
HAVING TOO MUCH FUN
Scott
11-09-2002, 02:25 PM
met the mfr of the jack from china at the AAPEX show (sister show to SEMA). very nice people and seemed to be very reasonable product for the price. do you guys find any play in the handle? any slippage?
-dan
11-10-2002, 09:54 AM
The handle was held in by a knob on top of the frame. It was up a little high and could hit a low car, so I replaced it with a bolt. The end of the bolt was turnned down to let the handle turn for release.
The lift on this jack is also high enough so it can be used on the trailer for hiway problems. (One axel, one side)
The handle is two parts. The top half comes off by a push button. Makes packing easy and have used the handle end as a pry tool and as an extension for a lug wrench.
HAVING TOO MUCH FUN
Scott
11-25-2002, 02:08 PM
NJ
Just got my Harbor Freight jack in this morning. It's really quite a piece of workmanship. Those Chinese slaves really know how to put out a good product. I guess if they screw up they go to the wall!
Anyway, it fits right under the sidepipes. Six pumps and its up!
So what do I use to polish it??
Roscoe
Roscoe
11-25-2002, 02:15 PM
Roscoe,
Nobody around here uses wax . Go to the All Waxing forum, I am sure you will get good advice there.
Sure glad everybody is buying those Aluminum Jacks, perhaps I won't have to be looking for mine anymore.
Cranky
03-01-2003, 03:19 PM
il
Cobra Make, Engine: #1459 w/460(sold)New(used),spf w/427s.o.(sold)
Harbor freight
Has anyone had any problems w/the al. jacks from HF? They look real nice but only come w/a 30 day warr. The welds and every thing look nice but the seals? Would appreciate any advice.
sparks
03-01-2003, 03:30 PM
SC
Had mine for a year ,use it every day and have never had a problem.I do not baby it though,it is my shop lift. chuck
03-01-2003, 06:23 PM
IL
Colors!
In the latest Harbor Freight catalog, there are now four choices for these jacks. In addition to the bare aluminum and blue finishes, you may now choose red or gold as well!
Fast Farmer
