Go Back   Club Cobra > General Discussion > All Racing Talk
Old 04-22-2006, 05:13 PM
Ant Ant is offline
Default Fuel Cell & anti-surge pot
Is it necessary to run a separate anti-surge pot/fuel pump next to the fuel cell, in order to prevent fuel starvation?
I ran a fuel cell in my race Cobra sometime ago and if the fuel got down much below half full, on some bends I got fuel starvation. I dare say it can hinge also on the selection of type/make of fuel cell!
A J. Newton
The 1960's rocked!
Old 04-24-2006, 02:22 PM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
I had Fuel Saft build me a custom unit for my CR. I had to later open it up and insert a collector (see attached) and mount my fuel pump lower to avoid the same issue you speak of. If you are running an electric pump, you have to get it low - preferably at the bottom of the tank. Lastly, raising the fuel level in the carb helps too.
Old 04-24-2006, 04:08 PM
Ant Ant is offline
Default Fuel Tank
Curt,
What I really need is the common system with two pumps, and having a separate small diameter tank eg 6" X 12-15" h, with a bypass connecting it to the main tank, so everything equalizes or if one pump goes harder than the other! But I feel with proper fuel system design one good pump and return line is all thats necessary.
If I make an alloy tank with baffles and a central pot the problem can be fuel getting to the pickup as well as holding it there with baffle design, I made a three cylinder design which sat on a flat bottom tank which had (3) different diameter tubes, and a 3/4x3/4 slot in the bottom of each one, but the inner cylinder had the slot facing forward so under acceleration/cornering fuel stayed there and the second cylinder had the slot on the rear, so under braking this contained the fuel, and the last was like the inner, this solved the problem of larger flat Cobra tanks, but that car was on radial tires, not slicks!
Having said all that I reckon I am better making a sump to go below the tank with say about (4) 3/4" diameter holes in the tank floor feeding it, and fill the tank with foam, and maybe have two or three big baffle plates with the corners cut out to restrict slosh! Whats the old saying keep it simple, but its still got to work!
A J. Newton
The 1960's rocked!
Old 02-12-2007, 05:24 PM
WildBill3's Avatar
we run a log on the side of the carb 830cfm and have never starved but we are feeding with a 1/2 inch line all the way to the carb on a manual hv pump .. good luck
