01-26-2008, 09:36 AM
OH
Cobra Make, Engine: Shell Valley- 390 FE, 4 speed toploader, 3.50's
0-60 MPH times (I know, I know)
I know, another time question, but with the snow on the ground and the 15 degree temps, I need something for a little motivation. I's sure some here have close to the equivalent of mine- or what it will be anyway. Im curious as to what a realistic 0-60 MPH time would be for my car. Also, I know there are alot of variables, but i'm just looking for a realistic time.
SVC Cobra- approx. 2600# (according to SVC)
390 FE, 400-420 HP
WR 4sp toploader
9" rear w/ 3.50 gears
Also, the clutch and type of tires are obviously important. Although undecided on particulars, the clutch will be worthy, and the wheels/tires will be 17" with modern "performance" type compound.
Any ideas on realistic times?
Greg
01-26-2008, 02:43 PM
NJ
Cobra Make, Engine: ERA 427 SC with 428 PI
I don't speed but I recorded my 0 -55 @ 2.3 sec.
"Is it original ?" -- " Yes! But some parts are new."
It's just easier this way.
01-27-2008, 11:45 AM
OH
OK, what transmission and rear end are you running?
Nobody else? Man, I thought i'd get a few responses anyway. I was just wondering if 4.0 seconds is realistic, or what?
Greg
01-27-2008, 12:15 PM
4 secs is slow !!
01-27-2008, 12:26 PM
Ont
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Here are a couple of links to performance calc sites. They don't take into account the gearing and tires, so I think the results are a little optimistic.
Car Stats - Calculator
Wallace Racing - Automotive Calculators
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
01-27-2008, 12:58 PM
Hey blue, I have a 390fe w/ 411 rear end and 4 spd toploader (wide/close i don't know?). I don't know the HP or torgue either but it seems like me counting 1001 and 1002 and I'm there at 60. Of course I count slow. All the way through 1st gear and the a short time in 2nd bam 60 mph. Very inaccurate I know but thats all I got right now. It's always fun till your going fast then it gets a bit more interesting. Always play safe.
02-02-2008, 12:16 PM
If you tried a 0 - 60 mph run on a normal road with, sea level, 12 inch rollout on decent tires and to include a good 1 to 2 shift you'd probably see around high 3s to low 4s. You'd probably knock off a half second at the drag strip if the track was prepped. If you had no shift before 60 mph you could knock off another .2 to .3 seconds.
02-02-2008, 02:46 PM
Cobra Make, Engine: Midstates, Genesis 427 S/O
I'm no "race car driver", but the one time I did time it 0-60 . . . 2.8 sec. I through those pants away
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
02-02-2008, 05:36 PM
what testing device did you use?
02-03-2008, 09:40 AM
OH
Thanks for the info guys. It's nice to see those kind of numbers coming from someone else other than yourself. Does that even make any sense? LOL Kind of a reality check.
Greg
02-03-2008, 12:16 PM
Oh
At the strip I run a 1.4 60' time which comes out to 58 mph. According to the one calculator above inputting my 1/8 time and mph it comes out to 1.81 0-60
Jack
XSSIVE .....
02-03-2008, 08:09 PM
Those calculators for the drag strip are pretty fun. I came out with a 2.3 0 - 60 for a 1.7 60 ft and a little over 104 mph at the 1/8.
Here's a G-tech reference with a standard 12 inch rollout for a few cars I tested on a normal roadway. These are realistic times for good drivers with average traction on an average road. I have quite a few files of assorted cars from myself and others from over the past several years.
02-03-2008, 08:40 PM
AL
0 to 60
I had to call a couple of guys to check the facts. But as best we can remember:
Three years ago Coach was going to swap his 5.0 EFI for a carb'ed 408. I asked him if he had check the 0-60 time before he pulled the 5.0. He said he had not. He call Jeff and they took a GTECH to a back road at a local industrial park. Coach @ 170 lb., Jeff @ 185 lb., FFR with hard top and a trunk full of stuff about 2500 lb., Wed night in Jan. cold but I don't remember how cold, below 50 degrees, Kumho tires (not a good choice for a Cobra) lots of wheel spin, even in hot weather.
0 to 60 mph in 4.6 to 4.8 seconds.
Coach was mad because FFR advertised something like 3.6. I reminded him of the tires, cold weather and extra weight. The next day they swapped the motors. He never checked the 408, but it was a lot faster. He did buy better tires. He sold the FFR and built a Hurricane with a KC 428 stroker 461 ci with 601 HP. Mickey Thompson tires and he still has a traction problem
Dwight
02-03-2008, 08:48 PM
AL
could not edit my post
Here is a picture of the stuff in the trunk of Coach's FFR. I'm guessing 70 lb of tools, water, antifreeze, oil, cloths, everything you need for a cross country trip.
Dwight
