Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
December 2025
Old 10-10-2010, 03:34 PM
Cobra Make, Engine: Contemporary Cobra
Default front holes for bumpers/finish line gromets
what size hole are you suppose to drill when using the front gromets from finishline? I had already drilled .75" with a hole saw and was thinking of usinf a step bit to enlarge the hole...ant thoughts?
Jon
Old 10-10-2010, 08:05 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Jon:
It has been 10 years but I believe I followed the manual and used a 1-1/4" hole saw.
I did what the manual said to cut the grommets provided.
Never did like it and never could get the glue to hold especially in the front.
I ordered the grommets from Finish Line a couple years later and with a little maneuvering got them to go into the holes in back and up front. The fiberglass is a bit thicker than it should be for the grommets but it worked and have been happy with them.
I would call Finish Line and ask them what size hole to use with their grommets before you take my word on what I did. Maybe some of the other guys will chime in on this thread.
Jim
OhioCobraClub.com
Old 10-10-2010, 08:17 PM
mickmate's Avatar
Get the grommets in hand and measure them with a claiper inside the groove. I also typically thin down the glass around the back of the hole edges to set them in there.
mickmate
http://www.actoncustom.com/
Old 10-11-2010, 06:35 AM
Roscoe's Avatar
If you spray the grommets with silicone they will slip in just like a wet....ah....er...well, you know.
Roscoe
Roscoe
Old 10-11-2010, 10:30 AM
MFE III's Avatar
Cobra Make, Engine: Hurricane Motorsports, 427w
I think the 3/4" hole is a good start. Then I used my Dremel tool to grind it out to the oblong shape you need for the grommets to slip in. Don't make it too snug in the hole or you'll have problems sliding the tubes through.
Matt
Hurricane Motorsports #1053; 427w
