Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 01-14-2011, 02:42 PM
Cobra Make, Engine: Contemporary Cobra
Default best type of insulation
with so many mfg's of insulation which type is best: Butyl, Close Cell Foam , Asphalt based or Cermanic for the interior of the car. Each Mfg make a variety of products...so, what realy works?
Jon
Old 01-14-2011, 03:02 PM
Cobra Make, Engine: kirkham stroker 48 webers
Lizard Skin...
Old 01-14-2011, 04:52 PM
Kramer's Avatar
Cobra Make, Engine: ERA 739
what are you using it for....inside the car, outside....
Old 01-14-2011, 05:48 PM
Default Inside.....
This for inside...but what I am looking for is not the name of the product but what it is made of and if you like it!
Jon
Old 01-14-2011, 05:58 PM
Kramer's Avatar
I don't know how to refer to it without the name, but I like the dynamat products. I specifically used the dynamat extreme matting. I found it easy to work with and very little heat or engine noise (besides the obvious roar of the pipes) comes though. Hope that helps.
Kramer
Old 01-14-2011, 06:30 PM
juansofla's Avatar
Default Insulation does nothing.
No need for any insulation, it is not the floor/firewall , it's the air all around... wear ear plugs for the noise of the wind, like a vacuum, and the low bass sound of the sides pipes... the heat of the exhaust pipes is all around the car, you fell like you are on a frying pan, that heat feels like radiation from an oven, on your face and neck... it is really a terrifying experience to ride on a cobra, the passenger side has a handle called "panic handle"... insulation?
