Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
December 2025
Old 01-28-2012, 08:28 PM
Cobra Make, Engine: acc
Default water pump
What are you guys using to block off your heater hose ports on the water pump. I'm using a Mildon high volume. I looked at tapping the ports and use a plug but the walls are too thin. The ports are part of the casting, so any ideas? Dave
Old 01-28-2012, 09:36 PM
Rick Parker's Avatar
Assuming there is enough material in the casting, cut the ports off and thread the remainder in the waterpump body for a tapered pipe plug. You'll never have to give it a second thought. Do it once.
Rick
Old 01-29-2012, 07:58 AM
Dwight's Avatar
Smile heater
you can buy rubber end cap (make sure they are for heater, hot water) and cap the ports. You hold them on with hose clamps. You may change your mind later and add a heater.
Dwight
Old 01-29-2012, 10:28 AM
mreid's Avatar
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Here you go:
Rubber - Plug and Cap Fittings - Fittings & Hoses - SummitRacing.com
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 01-29-2012, 07:50 PM
Default water pump
Thanks for the ideas
Dave
