Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 10-14-2012, 07:58 PM
Cobra Make, Engine: A&C 427 s/o
Default rear end
i have everything to put my rear end all together except for the brakes. Do you have to have the brake your going to use before you put ur center section and axles in?
Old 02-03-2013, 06:25 AM
Cobra Make, Engine: A&C (near future)-460
cobrabritt83 - I got my rear disk set-up (11" Disk) from AC. The bracket that holds the caliper goes between the axle outer flange and the rear end housing. So you can install the pumpkin (center) but don't set your axles in . If you are using drum brakes - I'm not sure what you need to do.
PJ
Old 02-03-2013, 11:22 AM
Cobra Make, Engine: Contemporary Cobra
Default Rear end
You can install the gears in the diff and then install the rear end to the frame.
What are you using for rear brakes?
Jon
Old 02-04-2013, 08:45 PM
Yes, you can install the rear end (Diff) - then install the axles. Mine has been a slow build ~3yrs+ so far - but the Rear Disks are 84-86 Mustang and the calipers are '86 Caddy's with emergency brake hookup. The front calipers are 86 Chevy S10 with 75? Granada disks - All are 11 inch disks. everything seems like it fits fine.... probably another year before I finish.
PJ
Rate This Thread:
