Like Tree1Likes
  • 1 Post By bobcowan
Old 11-25-2012, 04:26 AM
Default Striped screw in windshield
Threads are striped in one of the holes in the side of the windshield it's a
# 10 screw ....I have a Lexan windshield, any ideas how to fix it....
Jon
Old 11-25-2012, 05:35 AM
Cobra Make, Engine: jbl
fill it with epoxy and redrill.
Old 11-25-2012, 07:30 AM
bobcowan's Avatar
JB Weld!
The threads are in a brass strip behind the chrome trim. You can remove the bras strip, shoten it by 1/2", and redrill all the holes.
Bras is fairly soft. You could use a center punch around the perimeter of the hole to make the hole smaller. Then retap the threads.
Somewhere along the line I remember some body was selling a SS replacement for the brass strip. Much stronger material.
Wbulk likes this.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 11-25-2012, 08:53 AM
#10 screw might be a little tough going into jb weld.....
Old 11-25-2012, 10:44 AM
FWB's Avatar
FWB FWB is offline
I dunno, JB weld? sounds a bit half-arsed to me.....why not just put a thread insert in there and fix it right.
Fred B
Old 11-25-2012, 03:15 PM
bobcowan's Avatar
Because the brass strip is only 1/8" thick or less. I'v tried steel thread inserts in material that thin with poor results. OTOH, I'v used JB Weld with excellent results.
.boB "Iron Man"
Old 11-25-2012, 03:51 PM
FWB's Avatar
FWB FWB is offline
if it's that thin, your right an insert would be useless.
the frame on my car is much thicker on the sideposts than 1/8 inch. and i have the standard cobra frame.
at 1/8 inch that would give you 4 threads of engagement on a 10-32 thread
maybe an oversize self tapper might give the extra grab needed
Fred B
Old 11-25-2012, 07:22 PM
bobcowan's Avatar
The threads are not into the frame. They're into a brass strip behind the frame. You could over drill it, and then put a bigger screw in. But then you'd have to do that for all of them. And if you wanted a flush fit, you'd have to drill and countersink all the holes in the uprights.
.boB "Iron Man"
Old 11-25-2012, 07:39 PM
dcdoug's Avatar
You can replace the brass inserts with stainless steel inserts. Here is the part from Whitby: Whitby Motorcars
www.partskeeper.com
Old 11-26-2012, 04:30 AM
Thanks, that will work...
Jon
Old 11-26-2012, 06:33 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
If the side frame is brass like mine, JB weld and redo.
Take your time.
I used SS screws and studs for the window frame with wings.
Hope this helps.
