Old 12-16-2012, 06:38 AM
Default Wilwood vs Explorer rear brakes
I have Wilwood brakes on the front 12.19 rotors and Explorer disc on the back
Would there be a big difference switching to Wilwood's on the back ...
They would also have 12.19"rotor
Jon
Old 12-16-2012, 08:14 AM
bobcowan's Avatar
A custom designed brake system for a limited edition vehicle is a fairly complicated affair. Lots of things to consider - balance of the car, MC bores and type, calipers, rotors, etc. In the end, though, it's all about balance. Every part of the system is designed to give the proper balance. Cobra Replicas tend to have a much better balance than most cars - much closer to 50/50. That usually means you'll need more rear brake than other cars - like Mustangs.
Ideally, you want the front brakes to lock up just a tad before the rears. That's a good indication of the "perfect" balance. How is your balance now? If that's how your brakes are performing now, leave it alone.
The more pistons you have, the better the brakes will perform - to a point, of course. If you have 6 piston front calipers with a 13" rotor, you would probably need to upgrade the rears to match. But if your fronts are a 4 piston with an 11" rotor, you're probably fine where you are.
Decide where your braking problems are, and then figure out why you have that problem. Then you can figure out what parts will fix that problem.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 12-16-2012, 09:06 AM
Jerry Clayton's Avatar
An advantage of the explorer rears are the parking brake
Old 12-16-2012, 12:41 PM
Cobra Make, Engine: #6101 streetbeast Ingelese stack EFI 351w/t-5 9" 4link 3.55
My Wilwoods came set up with the Explorer E-brake assy.
Old 12-16-2012, 01:39 PM
LMH's Avatar
LMH LMH is offline
What Wilwood setup are you using? Do you have any pics you could post?
Alba gu brąth
Old 12-16-2012, 02:52 PM
[quote=LMH;1223081]What Wilwood setup are you using? Do you have any pics you could post?
Larry[/QUOTE
Sorry no pics. I bought my Wilwoods from Hot Rods USA out of Vancouver Washington. (360)-882-0444. Hope this helps.
Old 12-16-2012, 07:11 PM
LMH's Avatar
LMH LMH is offline
Can't find their website. I'm always looking for a good e-brake kit for Wilwood calipers. Best ones I've seen and what I intend to use on my 289 is Kirkhams setup. I just hope I can still get them when I get to that point.
Alba gu brąth
