Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-09-2014, 05:39 PM
Cobra Make, Engine: Antique and Collectible, 428 FE
Default Cobra walk around video
Cobra is 98% done just a few things left before NYS inspection and warm weather. Here is a video running in the drive way.
cobra walkaround - YouTube
Old 03-09-2014, 05:53 PM
rcobrakit67's Avatar
Cobra Make, Engine: Antique and Collectible Autos 408w
Your cobra looks and sounds insane!!!! great job, Richie
Old 03-09-2014, 06:06 PM
1795's Avatar
Nice job with the build. It will soon be warm enough to take it out for a spin. Good luck with the inspection. Where are you located?
Old 03-09-2014, 07:23 PM
Thank you. I live in Clifton Park, NY just a little north of Albany. I've never had good luck with the DMV for anything over the years, I am hoping any inspection issues don't cause me to miss any warm weather.
Old 03-09-2014, 08:05 PM
blown871's Avatar
Cobra Make, Engine: SPF
Me likey!!
tell us more about it..........
Old 03-09-2014, 08:53 PM
Cobra Make, Engine: FFR
Sounds great!
Old 03-09-2014, 09:17 PM
Really nice looking, sounds great, what are the specs on the cam?
Old 03-10-2014, 09:28 AM
428FE, Edelbrock heads with mild work built by Brent at B2 motorsports, Comp cams roller lifters, Rockers from POP, Hydraulic Roller cam (duration@50 230/240 lift 553/555) Holley 750cfm 4150 double pumper, Edelbrock Streetmaster intake that has had some porting done.
Old 03-10-2014, 03:07 PM
buddyg's Avatar
Cobra Make, Engine: Superformance #1309 www.spfowners.freeforums.net
Sounds very healthy! Congrats and good luck with DMV
Superformance specific forum check it out!
http://spfowners.freeforums.net/
Old 03-10-2014, 06:09 PM
1795's Avatar
The motor sounds great, what is the estimate on horsepower? I just took another look at the video, and coming fresh off of a project in which I installed a heater/defroster in my car, I did not see any defroster vents on your dashboard. Did I miss them? NY will require defrosters to pass inspection. They normally do not check them during the regular safety inspection, but because it is a new build I believe that they are going to see them during the initial inspection.
Check with others to verify. There are quite a few cobra owners in your area and they will know more specifics about what the inspectors in your area are looking for. Good luck.
Old 03-10-2014, 09:05 PM
Correct I have no heater/defroster. I have heard that the inspectors don't care as long as you get past the paperwork/pictures part, but as a back up I will use a marine 12v electric defroster temporarily wired in.
As far as horsepower I'm hoping for around 500 not sure if I am there or not. This is my first FE build. Much more familiar with Ford small blocks.
Old 03-20-2014, 06:05 PM
Cobra Make, Engine: ac/428 pi
I have a 67 428 pi motor. Stock pistons, elderbrock rpm heads, elderbrock performer rpm intake. 830cfm quick fuel carb, 605/605 comp cam, and it did 407hp on the dyno with junk headers. with no port work.
Old 10-21-2014, 12:39 PM
Default Further info
Who manufactured the cam, what is the overlap, and is it 107, 108, 110 ???
