| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
08-19-2014, 11:39 AM
Originally Posted by saturnkk
Can anyone tell me if the A&C extrior mirror ($60) is the same model as the Finishline one that sells for $40?
My glass fell out and broke and I need to replace the entire mirror I fear... I would rather have one that aligns perfectly with the holes already there!
Thanks!!
If all you need is the mirror, consider an upgrade to a slightly convex, optical quality piece of glass. Of all the different "tweaks" I've done to my car, putting in the slightly convex mirror is at the top when it comes to making the car more drivable in traffic. A Replacement Convex Mirror that Really Works
Note: the stick on convex mirrors that you get in the auto parts store are better than nothing, but they are "too convex," and make things appear to be much farther back than they really are. The lightly convexed glass that you get on many high end european models is a huge improvement when driving a Cobra.
08-19-2014, 11:57 AM
MI
Thanks, but how would that attach? ...everything on the inside is gone.
08-19-2014, 12:02 PM
So this piece, which sits "inside" the outer shell of the mirror, and rotates/adjusts inside that outer shell, and which is held in place by one big screw that comes in from the front of the mirror, is all gone?
08-19-2014, 03:16 PM
MI
Here it is...
08-19-2014, 03:28 PM
It's all there. Just follow my instructions in the thread I included above and you'll need to order the convex mirror. I can't tell if the little white gasket that goes around the circumference is still in good condition on your photo or not. If it isn't, then order one of those as well, or fabricate it (it's really nothing more than a plastic coated wire thingy). Note that in my thread there are posts from others saying that you can get the glass from a cheaper source than where I got it -- that might be a good option. Having the convex mirror is really nice. It's very common in Europe, but I believe the US has a DOT rule that prevents their use on the driver side (another dumb rule).
08-19-2014, 04:07 PM
Here's How These Mirrors Go Together...
