| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
03-20-2004, 07:08 AM
NJ
Windwing install
I drilled and tapped my windscreen frame. It is much sturdier than using the existing screws. Not hard to do because it's brass.
I have larger pics that are clearer if anyone wants them.
Roscoe
Roscoe
03-23-2004, 04:29 AM
Hey Roscoe,
I tapped and drilled my existing holes in the brass insert and installed heli-coils. I didn't even think about drilling the pillar part of the windshield frame. Your idea is probably a lot easier than what I did, because I had to disassemble the glass from the frame that surrounds it. Oh well, I'm a big dumbie sometimes.
John
03-23-2004, 06:27 AM
CA
Cobra Make, Engine: Midstates, Genesis 427 S/O
Roscoe,
I'm preparing to install mine as well. Did you tap them fine thread or coarse, #10 or #8 dia?
slithering
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
03-23-2004, 06:57 AM
NJ
Don't know for sure what the thread size is but I can say they are the same thread size as the windshield frame screws.
Roscoe
Roscoe
03-23-2004, 07:01 AM
Renegade Nuns on Wheels
Oh
For those of you with a soft top...... I have to take the wind wings off in order to get the soft top on. Aside from living with it, has anyone done anything to correct the issue so that the soft top can be installed with the windwings in place? The 'snap' that holds the soft top to the windscreen will not snap down into place with the wind wings on the car.
Thanks
Rick
03-23-2004, 07:04 AM
Oh
Roscoe, I was just reading your dyno article in Kit Car this morning while on the 'throne'. Did you ever run a holley on that motor? If so, what do you think of the Demon by comparison?
Thanks
Rick
03-23-2004, 07:08 AM
NJ
Rick,
Never ran a holley on it. The holley is a good carb but I think the BG carbs are a bit better quality. I've heard of some that have had problems with both. The BG Demon will take pretty much all holley parts, gaskets, jets, etc.
Another carb that is good, but a bit more $, is the AED. Nice carb.
Roscoe
Roscoe
03-23-2004, 08:11 AM
NY
Cobra Make, Engine: A&C 351W, C4
Windwings Install
I did what Roscoe did. I drilled and tapped holes in the windshield upright posts. I believe I used #10 NC screws. I used stainless screws and went right through the posts and secured the other side with stainless acorn nuts.
03-23-2004, 09:10 AM
CT
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Word of caution... If the screws you use are even a wee bit too long, what could occur is that the screw will touch and then push into the windshield glass.
What happens then is that the windsheild will either crack right then and there, or, will crack some time thereafter (like on a real hot day when the glass expands or vibration sets the glass against the screw).
You want the length of the screw to be just long enough to give you good bite and purchase in the frame but not too long to be near the glass. You have to be carefull when drilling too I would imagine.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
03-23-2004, 09:20 AM
NY
Hole location
Red,
What we're talking about is installing the windwings in a fashion other than what is prescribed. The prescribed installation calls for removing screws that hold the windshield to the posts and replacing them with longer screws to accommodate the thickness of the windwing mounting blocks.
Instead of doing it that way; drill new holes to the rear of where the windshield mounting holes are and tap the holes and mount the windwing blocks using the new holes.
Since the windshield posts are tapered from the top to the bottom, there is plenty of room to drill the new holes without it interfering with the windshield.
03-23-2004, 09:28 AM
NJ
Here's another shot of the upper mount:
Roscoe
03-23-2004, 09:34 AM
ME
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Not bad Roscoe, but couldn't you have used a pretty allen head bolt?
Replica is not a dirty word.
03-23-2004, 11:51 AM
Club Cobra Member
Fl
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
Nice job Roscoe!
03-23-2004, 12:30 PM
NY
Wings
I used slotted head stainless screws, but I like the idea of using Allen heads. Anyway, heres a few pics.
By the Way: Thanks Roscoe, you gave me the idea to mount the wings this way.
Wing Install !
Wing Install 2
Wing Install 3
03-23-2004, 04:02 PM
Nice job guys. How did you all know I just ordered my windwings and was wondering how to install them. Thank you for all the wonderful information. I really like the alan head idea. Has anybody had any luck with the top latch not interfering with the windwings, not that I put the top on much, but just food for thought. Thanks again.
Corky
03-23-2004, 04:46 PM
SC
Actually you do not need to tap if you drill through the back of the post like Tony did.Just drill through and secure with nice nut. chuck
03-24-2004, 06:41 AM
NJ
I didn't use a nut I just put loctite on the screws and made sure they were the proper length.
Roscoe
Roscoe
