Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 05-31-2005, 05:57 AM
Cobra Make, Engine: A&C- 351w 5spd
Default Trans/Pinion Angle
Looking for some advise. I installed my motor and trans yesterday and noticed that the tail shaft of my trans is about 3 inches higher than the pinion in the rear. I have the std. rear link arms (non-adj.), so I guess it would be kind of hard to change the pinion angle, if I have to. Would my current driveshaft be too severe? Any suggestions or opions? Thanks, Jerry
Old 05-31-2005, 06:53 AM
Roscoe's Avatar
Check out this old thread regarding angle
Antique&Collectible build help
And you may want to upgrade to adjustable uppers.
Roscoe
Roscoe
Old 05-31-2005, 08:06 AM
392cobra's Avatar
6th Generation Texan
Jerry,
Below is a link that will explain the angles you need and how to measure them.
http://www.drivetrain.com/driveline_angle_problem.html
