Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 07-30-2006, 05:58 AM
Cobra Make, Engine: A&C , 466 Ford, 5speed Tremec
Question Brake master cylinder & Fuel pump ?
Hi Guys,
I'm still in mock-up stage and gathering parts. My questions are what mastercylinder are you using for the four wheel disk brakes. Joe said I could use an 84 vette booster and cylinder but I want to use as many Ford pieces as possible, I know sounds dumb huh. My other question is what brands of electric fuel pumps are you using? I noticed what looks like a Holley on Aaron's pictures, but the last one of these I had on my street rod was so noisy I could hear it over the exhaust and its a 460 with 3" glasspacks. Thanks ,Sam
Old 07-30-2006, 08:10 AM
Roscoe's Avatar
Sam,
I'm using a Tilton Racing floor mounted pedal set with three master cyl's. I have a Tilton Racing hydraulic throw out bearing. I upgraded the front calipers to 4 piston Wilwoods. No booster.
Also I'm using an Aeroquip elec pump mounted on the inner chassis just under the drivers seat. They all make noise but I threw my Holley away cause I had nothing but trouble with it.
Roscoe
