Old 06-04-2007, 09:23 AM
Cobra Make, Engine: A&C , 466 Ford, 5speed Tremec
Question Front Suspension Spacers ?
Hi Guys,
I have a front suspension question, when I bolted the front upper A arms tight to the frame the tires leaned out fairy severely on top. So I installed longer grade 8 bolts and with weight on the tires, backed the nuts off evenly until the tires were plumb with the floor. This leaves quite a gap (about an inch) between the A arms and the frame. I know that this is how caster and camber are adjusted, but I have never seen it require so many shims. I have noticed a few pictures posted of A&Cs with some sort of bar stock spacers being used to close the gap. Have any of you ran into this situation and if so what did you do? Thanks for any help you can give, Sam
Old 06-04-2007, 09:54 AM
I hqad the exact same problem. I went to the nearest autoarts store and bought camber shims. I also lossened the nuts, backed off the upper arm until my tires looked straight up and down and installed the shims. Used quiet a few. Its good enough now untill i take it to a shop and get the aliagnment done as per 1976 Mustang 2 specs.
Hope this helps
Automan
Old 06-04-2007, 11:09 AM
Roscoe's Avatar
I installed a 1/2" spacer before I brought it to the alignment shop. This is how one side turned out.
The drivers side is similar. Eventually I'm going to get the Pole Position adjustable uppers.
Roscoe
Roscoe
