Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
February 2026
Old 04-16-2008, 09:00 PM
Cobra Make, Engine: A&C 67 Roadster
Default Roll Bar question
Hi - I'm taking ownership of an already built and titled A&C 67 Roadster on Saturday (excitement is at breaking point) and have what hopefully isn't too much of a noobie question. It doesn't have the roll bar fitted (no holes drilled either) so does anyone know what kind of work is involved to do it now? I've seen pictures of the car body off and didn't see any obvious mounting points. Appreciate any advice. Thanks.
Jon - Frederick, MD
Old 04-16-2008, 09:16 PM
mickmate's Avatar
Hi Jon, do you have the roll bar? That should give you some idea of how it fits. We've been slipping the end into a larger tube and putting a bolt through both to hold them on. I have some pics if you need them.
mickmate
http://www.actoncustom.com/
Old 04-16-2008, 09:21 PM
Cobra Make, Engine: Cobra International body Waltech frame
Not that easy if body is now on. Wonder why previous owner din't fit them in?
MV
"A company that makes nothing but money is a poor company" - Henry Ford
Old 04-16-2008, 10:12 PM
Don't have the Roll Bar yet. After I've had a chance to look at the vehicle I plan to call A&C to get some info on their bar. I'm assuming that it would come with brackets and all, but what about a template for drilling the body? I guess I have some basic questions. Would be great if you can send some pictures.
The build is fairly bare-bones in terms of add-ons - no wipers, bumper/jack mounts, wind wings etc.
Old 04-17-2008, 04:36 AM
mickmate's Avatar
We've put them on finished cars with no problems. If you're careful with the layout and your measurements it will be fine. I have a layout for the hoop holes I can send you. The rear brace is done to match the hoop.
mickmate
Old 04-17-2008, 07:57 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Jon:
When you order the roll bar from A & C they should include the bracket for the two down tubes and the bracket from the rear downtube. I had to slightly modify my brackets. The brakets bolt to the frame, you have to locate them and then drill thru the chassis tubes.
Doing it with the body on is the only way to do it.
When you order ask Sonny for a manual.
The manual should give you the layout, but be careful with the position of the front two downtubes. Look at the rear wall in the interior. You must make sure you drill so you do not run into it.
The rest of the parts like, visors, winwings and bumper extensions and quick jacks or bumpets you can get from Finishline.
Be careful drilling into the body, put tape down and then use a hole saw bits, go slow, it is easy.
Good Luck.
Jim
OhioCobraClub.com
