Old 03-04-2009, 06:01 AM
Cobra Make, Engine: A&C
Default How did you line up the bumper holes?
Any good tips on projecting the holes from the bumper supports to the fiberglass? Not to worried about the back but the front are a separated by 3" to 4".
Old 03-04-2009, 08:03 AM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
I don't have an A&C, but I used a welding rod to locate mine on a Midstates. Centered the welding rod in the frame mount for the bumpers and marked the holes. Drilled a small hole, checked again to insure it was where it needed to be.Then drilled to the proper size. Good luck
Old 03-04-2009, 08:42 PM
Thanks I'll give it a go.
Old 03-05-2009, 09:15 AM
I actually used the threaded rod and mounted it as close to the inside of the bumper with the nuts. That way i knew that the circle i marked on the inside of the fibreglass would be correct. Drilled first with a 1/8 drill bit in the center and finished fron the outside using masking tpe to keep the fibreglass smooth.
Automan
Old 03-05-2009, 09:42 AM
Ron61's Avatar
Post
I also used Automan's technique. Worked out great.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 03-05-2009, 02:48 PM
jerry w's Avatar
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Same technique as above. I used threaded rod, extended it thru the frame holes till it touched the fiberglass. ( I secured it with a nut on each side of the frame) Marked where the hole should go by tracing around the rod on to the fiberglass. I drilled a very small hole from the inside of body to outside, just to locate the holes and make sure I liked where the placement of the bumper would be.
Jer
Jerry
Old 03-06-2009, 05:03 PM
Thanks guys I extended the threaded round untill it touched.
Just looking at that fiberglass dust makes me itch.
