Old 10-04-2009, 08:03 PM
DWRAT's Avatar
Default Fuel mileage
I checked my mileage on the trip to Johns today.
I did 270 miles total and used 13 gallons of fuel.
So I got just a tad better then 20 MPG.
Does that sound about right for a easy road trip?(well it was easy on the way down as MikieC was leading and he never broke 55 MPH) on the way back I averaged about 80 MPH.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 10-04-2009, 08:09 PM
thats not bad at all............
Old 10-04-2009, 08:20 PM
Dan, you got a hybrid?
AZ Bob
Old 10-04-2009, 09:08 PM
Rick Parker's Avatar
DWRAT: What trans and gearing do you have.
Old 10-04-2009, 09:19 PM
DWRAT's Avatar
T-5 trans and not sure on the gearing.
2000 RPMs = 75 MPH
2100 RPMs = 80 MPH
FFR MK1---Sold
No more Furds.
Old 10-05-2009, 05:32 AM
Bill Bess's Avatar
My RPM's are about the same with a 3.25 rearend and a Tremic TKO w/.82 OD 5th gear.
My gas cosumption is a differednt thing...average 14.5 on the open road...hard to keep it under 80 mph.
Bill
Old 10-05-2009, 06:45 AM
Danr55's Avatar
Bill, You're doing better than I am. I get about 12.5 MPG on the road at 70-75 MPH. I can bump that to about 15 to 17 if I do 95 MPH. Turns about 2500RPM at 95 MPH.
Dan in Arizona
CCX3209
Old 10-05-2009, 06:50 AM
Bob In Ct's Avatar
Hey DWRAT:
Both of your numbers cannot be correct. If 2,000 RPM = 75, I calculate 2100 RPMs to be 78.75. Regardless, you are running a very tall top gear. My top gear is 2.54 (overall, 3.73 w 0.68 OD) and I turn 1,900 RPMs at 60 MPH.
Old 10-05-2009, 06:51 AM
twobjshelbys's Avatar
3.54 rear end, Tremec TKO600 with .82 rear end. Roush 427IR. I get about 18-19 on open road driving including in the mountains.
My crank only drives the alternator and water pump. Mileage increases when the HP goes to the rear end instead of accessories.
Old 10-05-2009, 06:59 AM
DWRAT's Avatar
Originally Posted by Bob In Ct View Post
Hey DWRAT:
Both of your numbers cannot be correct. I calculate 2100 RPMs to be 78.75. Regardless, you are running a very tall top gear. My top gear is 2.54 (overall, 3.73 w 0.68 OD) and I turn 1,900 RPMs at 60 MPH.
I agree my numbers don't calculate accurately at all but my general rule for speed is:
1900 = 70
2000 = 75
2100 = 80
That is more accurate then my speed which is off by about 8% or so.
FFR MK1---Sold
No more Furds.
Old 10-05-2009, 07:32 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
I don't know how anybody gets those kind of numbers. Regardless I stop after 120 Miles and fill up because I don't trust the damn gage. I reset it each time I fill up. The gage is all over the place when you turn hard to port or hard to starboard
It could be because of the Airstream I am pulling but I bet on a good day I am running 14 tops.
Fitz
fitzus1@gmail.com
Old 10-05-2009, 08:45 PM
mikiec's Avatar
I get about 24 on the road.
Love a small block, 3:27 gears and .64 5th.
Old 10-05-2009, 09:24 PM
Zoom This's Avatar
My 418W, 3.73 axle ratio, TKO 600 w/.64 OD gets 21 MPG at 70 mph at 2100 rpm on freeway. Around town....8-10.
Old 10-06-2009, 08:31 AM
lamaluv's Avatar
I've got two questions for you guys. 1. Did any of you buy your Cobras because of the "good" gas mileage that you get? and 2. When you get together with other car guys how many of you brag about your Cobras gas milage? Sorry I just couldn't help myself When I'm asked about mileage my usual answer is " I have no idea" or "who cares".
Dick
Old 10-06-2009, 09:04 AM
mikiec's Avatar
Actually when I built mine I had long distance cruising in mind. I also wanted a very docile small Block, ie 325 HP. The good mileage is a by product of that build.
So it looks good, sounds good and performs well.
Old 10-06-2009, 09:31 AM
Slick61's Avatar
8-10 mpg around town... about 12 mpg on long, extended cruises at 65-70 mph. Running a 3.73 rear end, a 0.82 overdrive, & a snotty cam in an aluminum 427W.
R. Smith
Santa Clarita, CA
Old 10-06-2009, 12:40 PM
8-10 around town and 12 on the hiway with a snotty wife sitting next to me.
Old 10-06-2009, 01:47 PM
Karl Bebout's Avatar
Mikiec, didn't you transpose your HP numbers? I thought your car was more like 235HP instead of 325.
Karlos
Old 10-06-2009, 02:26 PM
mikiec's Avatar
Only when I let you pass me.
Old 10-06-2009, 05:09 PM
Spoooky's Avatar
Cobra Make, Engine: 65' SPF (511 CID) FE 427 Alum Block Shelby /Roush 600hp-625fpt sideoiler
I get a whopping 8 to 10 in the city and a big 12 on the highway. Impressive isn't it??
