01-26-2010, 10:38 AM
Az
Can i lend you my flamethrower?
01-26-2010, 10:42 AM
Il
Originally Posted by Cobrabill
Something is wrong with the SMOG station.
I agree, I don't believe you can be required to "update" any vehicle to meet current standards. I'm pretty sure that they only require that it meet the standards for the year it was made.
WDZ
01-26-2010, 11:47 AM
AZ.
Thanks All,
The smog guy says it came with a Cat Conv. and I or somebody has removed it. I said I have had it for 10th year now and inspected the 9 years before at this STATION. All my print outs from them say (Cat Exempt N/A.) . Smog guy says they must have missed it because it needs to have one installed. Prove me wrong or install a Cat but I will not give you a PASS certificate. BTW it passed sniff with flying colors. I am being failed because of a equip. violation.
This is why I am asking Dodge ??? HOW DID IT LEAVE the factory?
So the BS begins
01-26-2010, 03:19 PM
Il
Let me present a possibilty. in the bike business, they made a larger percentage of the modles Ca. compliant..because Ca. is the largest bike (or were) buying state. We would, toward the end of a season or when someone wanted a previous model that was no longer produced, get bikes from warehoses that sometimes were Ca. ones. Those bikes came with all sorts of crap that the 49 state models didn't. Now, if someone removed that stuff because it wasn't needed here, the serial # would syill indicate it was a Ca. model. In this case it was usually evap. system. If the truck had been made for Ca. and was shipped to a dealer outside that state, it woulkd still be designated as having been built with what ever parts were needed to be Ca. compliant. If the dealer or some other entity had changed it to be more user friendly in the area it was sold in...that could be the issue. I don't know anything about what is or was required on diesel trucks of any kind, but that could be the issue. Now that they have computer links, maybe the serial # is for a Ca. produced model that was made 49 state. Might be worth looking into.
But vehicles of the era, I was under the impression, were required by law to have emission systems warranteed for 100K. I know Ford replaced the cats on my '89 5.0 GT with 90K+ miles for free. They were going to do it again about a year later when I went in to get an ignition or headlight switch update. My friend that worked the service dept. had not listed that they were installed in case I needed others later.So it would seem that the parts should be available somewhere. If you had a vehicle with less than that many miles and the system failed and a new part was needed, how would the mfg. be able to correct it?? That would make me think that IF those parts are needed they should be somewhere. there are now universal cat convertors that can be palced into any system, they just need the correct ends attached. That may be your only recourse if one is needed.
Not sure about the testing station, especially if it is a private enterprise. NJ had safety inspections begining in the early 70s and the inspection stations were run by...garages (that's what they were called then) and they seemed to be able to generate some extra income for themselves off the inspections. I believe that after I left the state that was changed because of ....fraudulent acts of the inspection stations. I know that I was failed twice. Once was for too loud exhaust (bone stock '69 428 CJ exhaust..untampered with) the other was because my aftermarket steering wheel was smaller diameter than the factory one. As you can see those were both EXTREMELY dangerous violations. There was no argument against the wheel, that's why I installed it, but when I pointed out that the exhaust was factory issue. They didn't care..it was too loud. I read in some publication at the time that the only way that car would have met the sound level was to stick a potato in each tailpipe. Call me skeptical, but I felt like they were trying to make some bucks off me. It could have been because I was in the AF and they thought I'd be an easy mark, I don't know. I re-registered it here and said screw 'em.
WDZ
01-28-2010, 06:43 AM
Cat Killer,
If you do end up needing to put a cat back on, I found a local guy with a used 4" cat that will sell for $50.00.
http://phoenix.craigslist.org/nph/pts/1561677696.html
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
01-28-2010, 08:31 AM
AZ.
I'LL TAKE IT !!! Thanks I will call you
01-29-2010, 07:20 AM
AZ.
The original build documentation for my 96 Dodge dually with a 12 valve Cummins was located at Dodge. My truck was not shipped with a catalytic converter. I will have this document faxed to a local dealer per their SOP. This adds additional traceability to the document is my guess.
I was told even a fax may take up to 48 hrs before sent but this is great news. I hope this is the end to this horror story but I still must get somebody to issue a PASS certif.
01-29-2010, 08:05 AM
It would still be a good idea to put a cat on your truck for environmental purposes.
Your favorite president would love you long time for that.
Otherwise, Cap & Trade may be affecting you soon.
FFR MK1---Sold
No more Furds.
02-02-2010, 01:33 PM
AZ.
I was told even a fax may take up to 48 hrs before sent but this is great news. I hope this is the end to this horror story but I still must get somebody to issue a PASS certify.
Well this past Friday I took the documentation from Dodge Corp. back to the original Smog station and talked to the same supervisor. He refused to issue a PASS certificate claiming the truck needs a Cat Convert per his documentation and I could protest with the State.
I made appointment with the State and headed across town to their offices. I showed them the documents showing truck never had a Cat. They looked up the spec's and also said it needs a Cat. I convinced them to call Corp. Dodge and gave them a number and department Supervisors name that sent me my paperwork. Dodge told them (the State guy) that the truck was not manufactured or shipped with a Cat. Conv. per the original VIN # provided. The State claims if it was shipped without a Cat then Dodge violated the Reg's but they don't care why .... to get a PASS certificate it must have a CAT added. Can you say I"M Screw'd
02-02-2010, 01:53 PM
"I'm screwed"... sounds like you are too!
Dan in Arizona
CCX3209
02-04-2010, 07:59 AM
AZ.
I met with a few folks at a local Dodge dealership yesterday. A complete search showed no Cat. Convert. on this truck when my VIN was used as a search filter nor others without the VIN filter. Continued research and various department managers lead me to the dealership GM. He agreed to take a look at what I and his folks had found.
Our meeting ended with him making a few calls to folks with a lot more horsepower than me investigating my options. So far I have been told it left Dodge without a Cat. Conv.
A generic Cat. Conv. from Autozone for the truck retails for $487.00 and then costs to modify current system and install labor. I do have the option to keep truck out of the county and register in Flag where I have a house but I loose use of truck here in Phx. I also face possible Fed charges if I knowingly sell truck to person in AZ. Smog counties without the Cat. installed.
02-04-2010, 08:53 AM
Would you just put a old used Cat on it and be done with this.
You talk about me and the way I carry on about things and it is nothing compared to you and this Cat situation.
Bend over and put the cat on.
FFR MK1---Sold
No more Furds.
02-04-2010, 03:39 PM
az
Come pickup your truck, and bring my money.
02-04-2010, 06:31 PM
Did you put a cat on Jeff's truck for him?
If you did, THANK YOU VERY MUCH. I've never heard a grown man cry like a little baby for 2 weeks straight.
FFR MK1---Sold
No more Furds.
02-05-2010, 06:19 AM
Shots fired!
Karlos
02-07-2010, 04:54 AM
az
Drip drip drip
02-07-2010, 11:12 AM
How much does a For Sale sign cost in Flagstaff ?
02-07-2010, 12:33 PM
AZ.
John,
I don't want to sell the old dually, love the truck. With 4:11 gears and that Cummins I can pull houses of their foundations. Never know when that will come in handy.
In the end I will install a Cat if I have to, darn hard to fight city hall and win. In the end I will have to prove their BOOK is wrong. I am not ready to give up yet though. Corp.Dodge is writing me a letter so I will wait and see if that works.
02-07-2010, 01:06 PM
Hey Jeff, do you have a decent State Representative in your area that might go to bat for you ? It never hurts to have one branch of the government question another branch. I know how you feel about the truck.
02-07-2010, 02:08 PM
Hum, my next store neighbor is the state representative for distric 10 and was speaker of the house for the last 2 years for my area.
I could hook you up with him if you need.
FFR MK1---Sold
No more Furds.
