| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
03-08-2010, 11:27 PM
AZ
Cobra Make, Engine: FFR III 302
Headlight stone guards
I bought some stone guards from Finish line, no instruction or tech support, how do you install. The reason everyone is so close , someone said make the person next to you smile, and we did.
03-09-2010, 05:29 AM
AZ
Loosen the headlight cowl and slide the tabs under the cowl then tighten it back down. Should hold in place.
Dan in Arizona
CCX3209
03-09-2010, 09:28 AM
AZ
My clips are held in place only by pressure from the chrome beauty trim ring, no screws. Has held fine for 9 years. I have 2 sets of clips, one short and one long. You may have to cut clip base to length. My guards touch the headlight glass. I also had to make the guard more "concave" by force to fit snugly over the headlight lenses. Bought original set from Finishline but soon after found similar set at Pep Boys.
AZ Bob
03-09-2010, 10:31 AM
AZ
Don't make the mistake of installing the stone guards directly against the lens, unless you are only after the "look".
Karlos
03-09-2010, 11:44 AM
AZ
Thanks for all of the good info.
03-09-2010, 11:45 AM
OH
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
I ended up buying a second pair of trim rings and welded the chip guards to them, then had'em powdercoated black. Now I can go stock look or race-car look with the removal of one screw per side. Easy!
- Dan
03-10-2010, 09:30 AM
AZ
Even with the stone guard not touching my old lens it was broken by a stone. I can only assume the guard saved breaks previously so I have had only 1. Now 1 old lens and 1 newer lens. Newer lens much more convex, old one almost flat.
AZ Bob
03-10-2010, 04:56 PM
Cobra Make, Engine: FFR MKII, warmed over 5.0, Turned 30,000 miles on January 1st run
Hey Skully,
Where do you live in Buckeye?
You can look at mine if you want, I live in Goodyear.
Posi....
03-10-2010, 10:41 PM
AZ
We live in Sun City Festival, wish is Sun Valley Parkway, or Bell rd when you pass Surprise. Give me a call when I could come over and see. Phone # 928 252 2656, John Yore
