Old 05-08-2010, 04:07 PM
mikiec's Avatar
Default dumb assed question
Water pump for a ford 302 has a backing plate. Does this plate need gaskets on both sides? One gasket for the timing cover side and another for the pump.
Mike
Old 05-08-2010, 04:17 PM
Rick Parker's Avatar
Absolutely!
Rick
Old 05-08-2010, 05:06 PM
OZCOBRA's Avatar
Mike,
You would be a DUMB ASS had you not put a gasket on ,the fact you asked the Question points to the fact you are a Wise man!!!... there is no such thing as a DUMB question!!
Old 05-08-2010, 07:46 PM
Finallygotit's Avatar
Cobra Make, Engine: FFR MkIII 302/345 Mass-Flo
Originally Posted by rick parker View Post
absolutely!
x2............
Dan
FFR6043 Delivered 04/29/07 Non-donor. Legally on the road 07/08/09. Finished 08/09/10
These cars are kinda like a lightweight, precision guided sledgehammer.
Old 05-08-2010, 09:43 PM
tin-man's Avatar
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Originally Posted by OZCOBRA View Post
Mike,
Not only a Wise man, but a fine Upstandin Gent too. tin-man
Be well, drive fast, live long
Old 05-08-2010, 10:30 PM
mikiec's Avatar
Good...
Now that I know I did it correctly, I can install it.
Mike
Old 05-09-2010, 12:33 AM
Doug I's Avatar
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
Just make sure that you put the correct gasket on the correct face of the plate. They are marked 'inner' & 'outer' so you should be right.
Pull a gear .... drop the hammer .... and enjoy the Drive !!
Old 05-09-2010, 09:21 AM
Kind of like belly buttons.
