Old 08-25-2010, 08:22 AM
mikiec's Avatar
Default Epoxy question
I need to glue wood to metal. It needs to never come apart.
What type of epoxy should I get?
Old 08-25-2010, 08:43 AM
Z-linkCobra's Avatar
I wouldnt use epoxy myself. Over time as the wood drys out and shrinks it will come loose. What are trying to bond exactly? You may want to look at using fiberglass resin. Fiberglass resin will actulay penetrate the wood where epoxy wont.
Old 08-25-2010, 09:38 AM
Danr55's Avatar
Mikie, go to your favorite gun store and buy a bedding kit.. Accraglas Gel. It will cost about $7.00. Follow the directions and you will have a bond that will never come loose. It's the best stuff I've found.
Dan in Arizona
CCX3209
Old 08-25-2010, 10:47 AM
Rick Parker's Avatar
Structural adhesive.
http://www.lord.com/Products-and-Sol...esives.xml/2/2
http://http://www.shop3m.com/3m-stru...3787&WT.srch=1
Any materials with different expansion rates will need an adhesive that does not get hard and brittle.
Old 08-25-2010, 11:48 AM
Y-NOT's Avatar
Cobra Make, Engine: too many to list
Exclamation Bondo Glass
Mike,
My Ferrari rear tub was bonded to the steel 280Z body with Bondo Glass. I also used it in the Willys to bond the interior hard wood to the fiberglass for attaching the interior panels and cloth. The Bondo does not run and has enough volume to fill the imperfections in the fit between the two surfaces.
My $0.02,
Bill
Life is like a roll of toilet paper.
The closer you get to the end, the faster it goes.
Old 08-25-2010, 01:18 PM
mikiec's Avatar
Dan,
That accraglass should do the trick. The last of the antique guns is finished and it is also a piece of junk. It is a 1890 single shot 12 Ga. The forestock was glued/epoxied before and falls off, this in turn allows the barrel to fall out. This gun will be hanging on a wall for the next 100 years in a museum at Pioneer.
Old 08-25-2010, 01:57 PM
Danr55's Avatar
Good. I've got some dye if you want to color it. Black, Red, Blue, Brown and White.
Dan in Arizona
CCX3209
Old 08-25-2010, 10:42 PM
tin-man's Avatar
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Originally Posted by mikiec View Post
Dan,
Mike, before or after you load it, wa, somehow I am doubtful I will ever go hunting with you. tin-man
Be well, drive fast, live long
Old 08-26-2010, 09:37 AM
mikiec's Avatar
Tinny..
This gun was manufactured in 1890. It was a cheap shougun sold to farmers, for gettin then durn varmits, through their local drygoods and apothicary stores. Cost back then was about $4.00. I was cleaning all the rust off this along with an 1863 Sharps and a 1933 Remington model 12 .22.
The shotgun was in 3 pieces when I received it. Just need to make it whole so it can be displayed on a wall. I would not even use this to hit someone over the head. The barrel might crack or bend. kind of like the stuff produced in China today
I have not been hunting in many, many years.
Old 08-26-2010, 11:24 AM
Danr55's Avatar
I know someone who is hunting Elk in November!
Dan in Arizona
CCX3209
Old 08-26-2010, 10:56 PM
tin-man's Avatar
Tinny..
Mike, OK point made, but really most things are not trash that are made in China, most all of the highend clothing and luggage people have their products made here as do most of the electronic items that get purchased, I phones come to mind, just made down the road from me.. Also, anyone who can send a multi stage rocket into outa space has got some good technology.
The products that come outa the factories I have built during the last twenty years are all ISO compliant, sell world class products globally and are very, very, profitabe. natch, I taught em how to make things right the first time
I am sorry to hear that you have not been hunting in many years. Cobra and guns, wa, what a life, well and errr, hmmm, also a lot of "wimmin" in between
John, AKA tin-man
Old 08-27-2010, 07:34 AM
wejnl^^
Old 08-27-2010, 08:02 AM
Danr55's Avatar
"wejnl^^" For those of us who do not speak (I don't have a clue, but I don't speak it) will someone please translate?
Dan in Arizona
CCX3209
Old 08-27-2010, 09:05 AM
lnfletcher's Avatar
I would call the guys at Raka Marine and tell them what you've got.
http://www.raka.com/index.html
I used their product to apoxy 318 engine mounts to wood stringers on an antique boat I restored and it will never come apart in my opinion. (metal to wood)
They have worked with me on several projects and know their stuff.
