November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-20-2010, 09:57 PM
Dale's Avatar
Cobra Make, Engine: FFR, Ford Cobra 5.0
Default Questions: FFR Door Latch
The pressed fitting on the left door latch of my FFR keeps breaking. Questions:
  1. Is this a known problem?
  2. Is there an easy fix?
  3. Does anybody have a left latch available for sale?
Thanks,
Dale
Old 11-21-2010, 06:30 AM
mickmate's Avatar
I pull them apart, epoxy and rerivet them.
mickmate
http://www.actoncustom.com/
Old 11-21-2010, 08:29 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Dale:
Here's a link to a fix for the problem. You're not alone.
Replacement latches can be had by (I think) Cobra Resotrers but they can be spendy.
DonC
http://www.ffcars.com/forums/showthr...highlight=donc
Old 11-21-2010, 09:57 AM
mikiec's Avatar
I did both of mine years ago using Wades method. Cost was about 75 cents each latch.
Old 11-21-2010, 03:04 PM
Dale's Avatar
Default Thanks
Thanks guys for the quick and detailed replies! Great information.
Old 11-24-2010, 08:13 PM
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
Send a message via AIM to Maricopa
Did the Wade fix too and it works great. Now all I have to do is quit losing those little screws that hold the covers on and drill and tap the knob on the driver's side latch that fell off.
Those UK-made parts are just wonderful....
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
Old 11-24-2010, 08:51 PM
mickmate's Avatar
I use a spot of silicone on the teensy cover screws. Those darn things sound like the suspensions falling out when the covers come loose.
mickmate
Old 11-24-2010, 09:15 PM
Yeah can you believe how much racket they can make! I ended up putting some closed cell, stick-backed foam inside 'em and using blue Loctite on the screws. Still found one missing the other day.
Old 11-29-2010, 11:22 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
The cheap doors on these things are useless as in useless! If I knew what I know now I would have had them fiberglassed closed. It is easier to just step over anyway and .....that's right...no burned legs!
Fitz
fitzus1@gmail.com
Old 11-30-2010, 01:42 PM
Karl Bebout's Avatar
Fitz, isn't stepping over the door kinda hard to do since you have the hard top on so much? You must be VERY flexible, and at your age!
Karlos
Old 11-30-2010, 01:50 PM
I've never heard of this problem, it is unique to FFR's. Or, is it unique to the latches that FFR supplies?
Old 11-30-2010, 05:37 PM
Fitz's Avatar
What top?
Fitz
fitzus1@gmail.com
