Old 06-21-2011, 04:16 PM
dave from mesa's Avatar
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
Default Engine is in
Got the engine, trans and drive shaft all hooked up. Thing looks pretty nice now. Only took us 2 tries (nothing goes in once, hell more like 4-5 times).
Target date up and running is Fall/Winter/Spring 201?
Oh yeah that's Karl and his 6yr old open bottle of dessert wine
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
Old 06-22-2011, 06:59 AM
mikiec's Avatar
Motor is in backwards.
Old 06-22-2011, 07:10 AM
That explains the wine.
Old 06-22-2011, 10:29 AM
Karl probably bought the wine 6 years ago for 99 cents and kept it for a special occasion.
AZ Bob
Old 06-22-2011, 02:11 PM
Karl Bebout's Avatar
99 cents for the whole case! Nuttin but the best for me and my friends.
Karlos
Old 06-22-2011, 02:49 PM
Danr55's Avatar
Must be ChamPipple.. That's a combination of 7up and Ripple.. Fred Sandfors's favorite.
Dan in Arizona
CCX3209
Old 06-22-2011, 03:00 PM
ItBites's Avatar
Wow Karlos, motor plate and all... You must be gettin serious about the 1320. I'm gonna have to step it up or get beat!
E. Wood
ItBites
Old 06-22-2011, 07:13 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Very Nice, Karl! It's about time you opened that bottle!
AND that the engine is finally in also!!!
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 06-22-2011, 07:21 PM
Eric, went with the fron mounting plate so I could use larger tube headers. I'd had tiny little 1 3/4" and got some 2" Headman block huggers. Should be better. Just couldn't justify dropping a ton on some custom made pipes. I've got almost enough power, without trying to squeeze every last ounce of it. The car will knock off 98% of the competition and still be nicely streetable, especially now that I have an OD transmission that'll make cruising a lot better.
Karlos
Old 06-22-2011, 09:28 PM
What he said.
Except maybe the "nicely streetable". Still gonna be a beast.
dave from mesa
Old 06-22-2011, 09:50 PM
*13*'s Avatar
Always a big step! Looks nice!
ERA FIA 2088
Old 06-23-2011, 03:23 PM
Cobra Make, Engine: FFR MK-I, 302, 780 Pro-Systems custom double pumper, 425HP
Wow, what a shinny engine compartment. Looks real nice Karl.
Mesa Mike
Old 06-23-2011, 04:19 PM
Mike B, did you mean "Shinny" or did you mean "Sh!tty?"
Shinny
From Wikipedia, the free encyclopedia
Not to be confused with Shinty.
Shinny (also shinney) is an informal type of hockey played on ice or the street. There are no formal rules or specific positions, and generally, there are no goaltenders. The goal areas at each end may be marked by nets, or simply by objects, such as blocks of snow, stones, etc. Bodychecking and lifting or "roofing/reefing/raising the puck" (shooting the puck or ball so it rises above the ice) are often forbidden because the players are not wearing protective equipment.
Ralph
Burma Shave
Old 06-23-2011, 05:27 PM
Danr55's Avatar
No Ralph, SHINEY like the top of your head!...Of course that could also be pointed, but that doesn't even sound close!
Dan in Arizona
CCX3209
Old 06-23-2011, 05:36 PM
Dan, I completely understand, but you need glasses!
Burma Shave
Old 06-24-2011, 01:11 PM
tin-man's Avatar
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Hi Karl, and what type of OD transmissions would that be? I have had some recent experience with OD transmissions: over drive, floating drive, not sure which drive, stay in first drive and does not even drive. So just curious.
tin-man is back in China.
Be well, drive fast, live long
Old 06-24-2011, 03:43 PM
All things considered, you have a wonderful sense of humor.
Old 06-24-2011, 11:00 PM
Hi Tinner, My new tranny is a 4L80e that is not electrically controlled. I didn't want to spend the additional big bucks it would have been to get the computer to run it electronically. Hughes Racing Transmissions, here in Phoenix, built it for me. I've been running one of their TH400 tranny for years, without any problems, and I am just a little harsh on it. The new tranny is pretty much just like the TH400 but has the 4th gear 25% OD. They built it with all the super HD goodies like the TH400 so I'm anticipating getting the same good service out of it.
Karlos
Old 06-25-2011, 02:23 AM
tin-man's Avatar
Thanks patrickt, its a Brit thing. That said, like everyone else I can get more than pissed and right now its simmering. Also, I am reminded I am in China and there is not a lot I can do except report my experiences on Club Cobra as a warning to those people who may be contemplating buying an engine and transmission. If the car gets fixed by Christmas when I retire I can live with that, if it doesn't work and we have more of the same, well thats when the s**t will hit the fan. I am thinking what has happened here has got to be a real marketing problem for Roush and Bowler and I intend to keep the pressure on. tin-man
Old 06-25-2011, 10:04 AM
The Bowler trans is a 4R70W Ford AODE transmission. Originally handled 500 ft lbs of torque in the Expedition, but is re-worked to handle more at Bowler. Final drive standard is .70. Here is a brief description: AODE and 4R70W Transmission FAQs - Baumann Electronic Controls, LLC
Correct me if I'm wrong here.
AZ Bob
