| S |
1 |
| 4 |
5 |
8 |
| 11 |
12 |
15 |
| 18 |
19 |
22 |
| 25 |
26 |
29 |
30 |
31 |
06-21-2011, 04:16 PM
AZ
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
Engine is in
Got the engine, trans and drive shaft all hooked up. Thing looks pretty nice now. Only took us 2 tries (nothing goes in once, hell more like 4-5 times).
Target date up and running is Fall/Winter/Spring 201?
Oh yeah that's Karl and his 6yr old open bottle of dessert wine
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
06-22-2011, 06:59 AM
NH
Motor is in backwards.
06-22-2011, 07:10 AM
az
That explains the wine.
06-22-2011, 10:29 AM
AZ
Karl probably bought the wine 6 years ago for 99 cents and kept it for a special occasion.
AZ Bob
06-22-2011, 02:11 PM
AZ
99 cents for the whole case! Nuttin but the best for me and my friends.
Karlos
06-22-2011, 02:49 PM
AZ
Must be ChamPipple.. That's a combination of 7up and Ripple.. Fred Sandfors's favorite.
Dan in Arizona
CCX3209
06-22-2011, 03:00 PM
AZ
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
Wow Karlos, motor plate and all... You must be gettin serious about the 1320. I'm gonna have to step it up or get beat!
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
06-22-2011, 07:13 PM
AZ
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Very Nice, Karl! It's about time you opened that bottle!
AND that the engine is finally in also!!!
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
06-22-2011, 07:21 PM
AZ
Eric, went with the fron mounting plate so I could use larger tube headers. I'd had tiny little 1 3/4" and got some 2" Headman block huggers. Should be better. Just couldn't justify dropping a ton on some custom made pipes. I've got almost enough power, without trying to squeeze every last ounce of it. The car will knock off 98% of the competition and still be nicely streetable, especially now that I have an OD transmission that'll make cruising a lot better.
Karlos
06-22-2011, 09:28 PM
AZ
What he said.
Except maybe the "nicely streetable". Still gonna be a beast.
dave from mesa
06-22-2011, 09:50 PM
OR
Always a big step! Looks nice!
ERA FIA 2088
06-23-2011, 03:23 PM
AZ
Cobra Make, Engine: FFR MK-I, 302, 780 Pro-Systems custom double pumper, 425HP
Wow, what a shinny engine compartment. Looks real nice Karl.
Mesa Mike
06-23-2011, 04:19 PM
AZ
Mike B, did you mean "Shinny" or did you mean "Sh!tty?"
Shinny
From Wikipedia, the free encyclopedia
Not to be confused with Shinty.
Shinny (also shinney) is an informal type of hockey played on ice or the street. There are no formal rules or specific positions, and generally, there are no goaltenders. The goal areas at each end may be marked by nets, or simply by objects, such as blocks of snow, stones, etc. Bodychecking and lifting or "roofing/reefing/raising the puck" (shooting the puck or ball so it rises above the ice) are often forbidden because the players are not wearing protective equipment.
Ralph
Burma Shave
06-23-2011, 05:27 PM
AZ
No Ralph, SHINEY like the top of your head!...Of course that could also be pointed, but that doesn't even sound close!
Dan in Arizona
CCX3209
06-23-2011, 05:36 PM
AZ
Dan, I completely understand, but you need glasses!
Burma Shave
06-24-2011, 01:11 PM
AZ
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Hi Karl, and what type of OD transmissions would that be? I have had some recent experience with OD transmissions: over drive, floating drive, not sure which drive, stay in first drive and does not even drive. So just curious.
tin-man is back in China.
Be well, drive fast, live long
06-24-2011, 03:43 PM
All things considered, you have a wonderful sense of humor.
06-24-2011, 11:00 PM
AZ
Hi Tinner, My new tranny is a 4L80e that is not electrically controlled. I didn't want to spend the additional big bucks it would have been to get the computer to run it electronically. Hughes Racing Transmissions, here in Phoenix, built it for me. I've been running one of their TH400 tranny for years, without any problems, and I am just a little harsh on it. The new tranny is pretty much just like the TH400 but has the 4th gear 25% OD. They built it with all the super HD goodies like the TH400 so I'm anticipating getting the same good service out of it.
Karlos
06-25-2011, 02:23 AM
AZ
Thanks patrickt, its a Brit thing. That said, like everyone else I can get more than pissed and right now its simmering. Also, I am reminded I am in China and there is not a lot I can do except report my experiences on Club Cobra as a warning to those people who may be contemplating buying an engine and transmission. If the car gets fixed by Christmas when I retire I can live with that, if it doesn't work and we have more of the same, well thats when the s**t will hit the fan. I am thinking what has happened here has got to be a real marketing problem for Roush and Bowler and I intend to keep the pressure on. tin-man
06-25-2011, 10:04 AM
AZ
The Bowler trans is a 4R70W Ford AODE transmission. Originally handled 500 ft lbs of torque in the Expedition, but is re-worked to handle more at Bowler. Final drive standard is .70. Here is a brief description: AODE and 4R70W Transmission FAQs - Baumann Electronic Controls, LLC
Correct me if I'm wrong here.
AZ Bob
