Old 11-25-2011, 06:25 PM
mikiec's Avatar
Default FFR guys
Which lokar throttle cable did you go with? Looking to change out my cable. I measured the current cable from pedal, following the curves to the carb and gor 48 inches. I looked up the 48 inch lokar cable and the housing is 48 inches but the cable is 60.
Reminder this is for a carb 302.
Old 11-25-2011, 07:12 PM
Mike, got the throttle cable from Autozone. Ford was a hundred bucks and paid 25 for the same cable. I am using mustang brake and throttle so may not work in your situation. I had no idea for part number so it was a 5 min search at the counter. I will look for old reciepts if you need the info.
Old 11-26-2011, 03:32 PM
bobcowan's Avatar
I bought the 60" cable. It's very easy to cut it down to fit exactly the way you want it to.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 11-27-2011, 04:28 PM
mikiec's Avatar
Thanks guys...
Problem fixed.
Old 11-28-2011, 07:37 AM
Cobra Make, Engine: FFR MK-I, 302, 780 Pro-Systems custom double pumper, 425HP
I used a lokar 36"
Mesa Mike
Old 11-28-2011, 10:22 AM
mikiec's Avatar
Thanks Mike.
I thought the stock ford cable was binding up. It ended up being the pedal pivot point.
It's nice and smooth again. May change out to a Lokar cable this summer.
