02-11-2013, 04:41 PM
Cobra Make, Engine: 1966 427 CRII SB Ford stroked 408
Brakes
Question: been told DONT run drilled/slotted rotors front or rear on my Cobra unless you intend to race. I want to replace the drums in back with disc's. no problem but was told if you dont buy Baer or wilwood (high $ rotors) you will burn brake and wrap rotor's, something about they take OEM parts and drill/slot them but the metal compound is weak. Is it worth it for the street. I would like your input guys.
02-11-2013, 05:24 PM
AL
If the guy(s) who was giving you advice was trying to sell you something, you ought to talk to someone else.
1. Drilled and slotted rotors aren't essential to good working brakes, especially for the street.
2. The front brakes do most of the work in stopping your car, so switching from drums to discs on the rear won't yield a noticeable improvement stopping IMO. It also won't put much heat into your rear brake rotors unless they are significantly undersized.
3. Lots of Cobra replicas, including mine, use factory style brakes designed for much heavier cars. Mine work fine even on the track with repeated max performance braking from 140 MPH.
Tommy
Previously owned EM Cobra
02-11-2013, 05:37 PM
az
Plus pad wear is more
Holes and slots can the be the starting point for a crack.
They look cool.
_____________________
02-11-2013, 05:41 PM
Stick with what you have.
02-11-2013, 06:16 PM
My understanding is that slotted/drilled rotors dissipate heat only marginally better but are weaker and can't be turned. But they look cool.
02-11-2013, 06:25 PM
What Lippy said. If you want to run discs and you're not going to race, stick with conventionals.
Dan in Arizona
CCX3209
02-11-2013, 06:42 PM
ok
Cobra Make, Engine: Lonestar, 427 Center Oiler
Slotted rotors are wonderful..... in the rain. Since I won't race in the rain, I don't feel the need for them. On a closed in car, sure they would be great. I wouldn't bother unless you just want that look.
Mat
02-12-2013, 06:42 AM
CO
Drilled holes and dimples are simply for bling. They provide no additional performance advantage. The holes have a tendency to propagate stress cracks, which require rotor replacement.
Slots are there to shave off a small amount of material with each sweep - kind of like a cheese slicer. When you're racing, the pads can get glazed from repeated hard stops. The slots help to keep a fresh surface.
On the street, or with autocross and drag racing, simple solid rotors are the most effective with a low cost.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
02-12-2013, 09:07 AM
Holes no. Slots yes. Slots relive gas pusher under hi timp. with significantly increases performance of the brake. Holes look cool but have no advantage over slots. Holes only lighten the rotor and can be the start of a crake. Disk are cool but drums work just fine. There is a lot moor to putting disks on and making them work then you might think.
Bill Emerson
02-12-2013, 10:29 AM
Cobra Make, Engine: FFR MK-I, 302, 780 Pro-Systems custom double pumper, 425HP
It's a myth that slotted and drilled rotors can't be turned. I Just had it done on my 13" cobra mustang (slotted and drilled) rotors. The local auto parts stores (autozone, pep boys, etc) won't turn them but a good machine shop can. The one I use (Basko) does it on a flywheel machine that give it a circular cut, which is best. I asked, "are these better or worse than a plain solid rotor?" Ray said "better, dissipates heat better". I'll take his word for it.
Mesa Mike
02-14-2013, 06:48 PM
I thank you all for the input I will just stick with a OEM style rotor for now.
02-15-2013, 07:00 AM
Good choice
Mesa Mike
02-15-2013, 09:55 AM
What he said.
02-15-2013, 12:27 PM
What they said.
Dan in Arizona
CCX3209
02-15-2013, 07:17 PM
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
What all them there guys said
02-18-2013, 10:39 AM
Az
Cobra Make, Engine: FFR MK3/302/570 street avenger
No wonder youse guys have so many posts. What Fitz said.
