Old 03-17-2013, 08:45 AM
Cobra Make, Engine: 1966 427 CRII SB Ford stroked 408
Default Exhaust question
Myth or fact
Old hot rodders trick for louder side pipes.
remove the side pipes, pour a little gas down the tube, light, roll the pipe to burn the angle hair inside glass pac put the fire out and reinstall, start and drive the car.
Old 03-17-2013, 08:56 AM
Cobra Make, Engine: #6101 streetbeast Ingelese stack EFI 351w/t-5 9" 4link 3.55
I have herd this also but a little diffrent. Use white gas(coleman lantern fuel) then just put the pipes back on and let the motor heat burn out the angel hair.
Old 03-17-2013, 09:01 AM
Cobra Make, Engine: jbl
i think i heard water in the glass pack funks up the glass and makes for more noise. can't remember if i tried or not. they usually burned out of themselves.
Old 03-17-2013, 11:31 AM
Danr55's Avatar
Who with a cobra would want more noise? I wear earplugs as it is..
Dan in Arizona
CCX3209
Old 03-17-2013, 02:07 PM
Jeff Classic would know. Wait till he replies. If you have enough patience your pipes will get louder with age. Mine did.
AZ Bob
Old 03-17-2013, 02:50 PM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Most of the mufflers I have taken apart did have a fiberglass mat or something resembling it in addition to baffles. The material over time shrinks and the air between strands seems to disappear making it more dense so less effective or louder. I would bet gas would not do a darn thing as it would not get hot enough ??? No ideas here.
My exhaust builder uses stainless wool to build his muffler with a ceramic mat also part of his muffler. He told me cheaper materials can melt into BB like objects that rattle and blow out the pipes.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 03-17-2013, 06:36 PM
mikiec's Avatar
Ask Fitz, what Gordon did to his pipes to get so loud you could hear him idle 3 miles away.
Old 03-17-2013, 06:47 PM
mikiec's Avatar
Ron fixed it.
Thanks Ron.
Old 03-17-2013, 09:32 PM
Rick Parker's Avatar
Depressing the thottle pedal works for me, saves the knees and is a lot quicker???
Rick
Old 03-18-2013, 07:51 AM
Scotchman's Avatar
Cobra Make, Engine: FFR MK3/302/570 street avenger
It's Fitz's Bad A%$ motor that makes all that noise.
