Old 10-05-2013, 04:20 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Default Wiper blades
My rubber is shot. Like I used it once last year. Where other than cut to the chase and get it from Finish Line? O'Reily has the bracket but not the 10 inch blade. Suggestions ?
Fitz
fitzus1@gmail.com
Old 10-05-2013, 04:24 PM
Karl Bebout's Avatar
NAPA, da Zone? That 10" size is just what the old VW Beetles took. Nuthin' special, just leetle.
Karlos
Old 10-05-2013, 05:11 PM
Danr55's Avatar
Anyplace that carries parts for British Motor cars. MG, Triumph, Austin, Austin Healy, etc.
Dan in Arizona
CCX3209
Old 10-05-2013, 05:55 PM
dave from mesa's Avatar
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
What are wiper blades?
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
Old 10-05-2013, 06:09 PM
DonC's Avatar
Try ANCO N-12R. Will have to be trimmed but not a problem. This is the rubber only. If you look closely at the existing you should be able to slide the old blade rubber out of the holder and just slide the new one in. Takes about 5 minutes including the trim job.
DonC
Old 10-05-2013, 08:21 PM
Don, is that before or after using the car for a stud finder?
Karlos
Old 10-05-2013, 09:47 PM
Wrong Don there Karl. I have replaced mine both ways. From Finish Line and buying a local rubber refill and trimming.
Here is another source for 9 inch blades only: Cobra Valley's Windshield Wiper Blades
AZ Bob
Old 10-06-2013, 09:10 AM
Oops! Sorry, DonC, I was thinking of DonM. Hate to cast aspersions where they are not warranted.
Karlos
Old 10-06-2013, 02:51 PM
Fitz's Avatar
Took Karl Man and Don C advise. Napa had rubber and you slide it to the sleeve bracket and cut to proper length = $6
Fitz
fitzus1@gmail.com
