Old 01-12-2014, 09:39 AM
mikiec's Avatar
Default Wacko qusetion
Point A to Point B = 26 inches. Point C is a fixed point in the distance.
If I move point A 1/8" to the left. How much do I have to move point B to maintain a straight line to point C?
Old 01-12-2014, 09:55 AM
CHANMADD's Avatar
Old 01-12-2014, 10:47 AM
If A, B, and C are in a straight line to begin with, the amount of movement of point C would equal 1/8" x the ratio of the distances between AB and BC (AB/BC=???? x 1/8")
Old 01-12-2014, 10:54 AM
Bernica's Avatar
Senior CC Premier Member
If A to B was a straight line in the first place, and C is in that straight line, you don't move anything. You still have a straight line. Unless I'm missing something or you are trying to make C equadistant between A and B. Sunday mornings are tough for math class!
Old 01-12-2014, 11:04 AM
This question is worded very poorly. It is not clear if the straight line is from point B to point C, but I assume so.
This is a trick question. You can always draw a straight line between any two points, so you do not need to move point B. Furthermore you can move point B anyplace in the universe and still draw a straight line to point C.
If the question is to get a straight line from point A to point B with point C fixed, after point A was moved, then the previous answer is correct, if you move point B to the right.
Old 01-12-2014, 11:28 AM
Danr55's Avatar
If A B C is a triangle, you don't have to move B at all. It is already in line with C. If A B C is a straight line, you essentially create a triangle when you move A so you would solve for the height of the triangle which would be the distance from point B to line AC. That would depend on the distance from A to C. Really need more information regarding the preliminary relationship between A B and C. If they are a straight line, it would help to know either the distance AC or BC to have a real solution. It almost sounds like we are adjusting iron sights..
Dan in Arizona
CCX3209
Old 01-12-2014, 11:52 AM
Since C is a fixed point and the distance from AC and BC is constant. Then AB is also wants to remain constant along an arc with C being the center point. To keep AB constant you need to move it the same distance along the line of the formed arc. In the end, it doesn't matter, you can always draw a straight line if you're sober enough.
_____________________
Old 01-12-2014, 11:55 AM
Bernica's Avatar
Agree on the triangle theory, if that's what he is asking. Not clear. Trying to solve dead-center on a circle between AB?
Old 01-12-2014, 11:56 AM
Karl Bebout's Avatar
"Wacko qusetion"
Yes, it is a Waco QUSETION.
Karlos
Old 01-12-2014, 01:35 PM
mikiec's Avatar
My bad. A B C are in a straight line.
Old 01-12-2014, 02:03 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Question
You would have to see it in order to know what is in it? Just like the OB Care. My answer is leave C along. Sounds like C is on the way to B or C is on the way to A. It doesn't make any difference. Are we all bored today?
Here I sit trying to give away a 110" X 36" one piece mirror? Along with answering a high school math sophomore test question...
Fitz
fitzus1@gmail.com
Old 01-12-2014, 04:04 PM
Bernica's Avatar
Don't forget to finish taking down the Christmas lights!
Old 01-12-2014, 04:08 PM
OK, so all three points sit on a hyperbolic paraboloid, right?
Old 01-12-2014, 04:54 PM
Bernica's Avatar
There's always Catia software if you are burning for an answer. Measures all points in space. When you're finished, you can design an airplane or the Disney Concert Hall! I'll just stick to a tape measure and calculator
https://www.youtube.com/watch?v=e04CjtjZ8lk
Old 01-12-2014, 05:00 PM
I've been trying to teach Chas non-Euclidean Geometry for years, but, man, he is a slowwww learner. I got him Mathematica for Christmas -- I'm hoping that will help.
Old 01-12-2014, 05:03 PM
Sounds like you need to go straight to your room B, since you, C, changed the criteria and became an A.
Old 01-12-2014, 05:09 PM
Bernica's Avatar
My son is math and Econ at UCLA. When I bring him a tough one (for me), I get the "One scoop chocolate, One scoop of vanilla...Don't waste my time!"
Old 01-12-2014, 05:53 PM
Bernica's Avatar
C has no bearing on the question, best I can tell and based on the original question. C could be on the moon. AB could move from here to infinity and still be a straight line. My 2c.
Old 01-12-2014, 05:57 PM
Ooooh, you're close.... The real answer will depend on whether you take the view that parallel lines meet at infinity.
Old 01-12-2014, 06:24 PM
Bernica's Avatar
Did not pick up on parallel lines anywhere. Only one line. You got dat double vision goin' again Patrick?
